builderbob
Posted: Thu Feb 22, 2007 7:52 am Post subject: soldering dry joints |
Hello i found a couple of dry joints in my palsonic tv. when i tried to resolder the joint my new solder "sucked off" the existing solder leaving no solder around the tag at all. have you seen this before and how do i resolder the joint |
Posted: Thu Feb 22, 2007 11:54 am Post subject: |
CLEAN JOINT AREA WITH A FIBRE PEN, AVAILABLE FROM GOOD HOBBY ELECTRONIC SHOPS, APPLY LIQUID FLUX, PREFERABLY NOT A WATER BASED ONE, AND ALL SHOULD BE WELL |
Restoration Guest
Posted: Fri Feb 23, 2007 12:37 pm Post subject: solder sucker soldering iron. |
YES,
the lead and pcb are burnt, corroded by being a bad connection, solder just runs off it!
Clean the Metal, scrape clean with a knife if you have to! when the metal is clean it will solder.
Tip! in desperation, if all else fails, Aluminum solder, with special flux will solder where others fail.
Melvyn. |
Posted: Sat Feb 24, 2007 6:40 pm Post subject: |
Follow the trace to the next component and put a jumper in. |
GL4000 service manual AP2640 3 NO PSU . • hfe au-ra z1 z2 z3 assembly cz RATIONA • 48-08 Philips • hfe onkyo integra dtr-70-2 80-2 en ONKYO • KV36XBR400 Part3 Sony • service Philips • hfe pioneer sm-g205 schematic Pioneer • 2sc3277 Inchange Semiconductor • Matsuki-Enesol (MPCAP-EneCAP) [SMD polym • mtb50p03hdlrev2 Motorola •
