RAUL
Joined: 09 Nov 2006 Posts: 23 Location: La Union, Philippines
Posted: Fri Feb 23, 2007 8:33 am Post subject: OLD PROJECTOR |
WE HAVE AN OLD SONY PROJECTOR MODEL VPH 1043QJ. HACC. MADE IN JAPAN. ITS SIZE IS LIKE AN EMPTY CASE OF BOTTLED SOFTDRINKS. THE PROBLEM IS THE THREEE SEPERATE LENSES INFRONT FOR THE COLOR RED, GREEN,AND BLUE WAS BROKEN. FLUIDS COMES OUT IN THIS LENSES. WHAT IS THE FUNCTION OF THIS FLUID? CAN I STILL USE THE PROJECTOR WITHOUT THIS LENSES? WHERE CAN I BUY SIMILAR LENSES? THANKS... |
Posted: Sat Feb 24, 2007 11:45 pm Post subject: |
It's like antifreeze. |
RODALCO
Joined: 28 Oct 2006 Posts: 30 Location: Auckland - New Zealand
Posted: Sat Mar 03, 2007 9:40 am Post subject: |
I think the fluid is to dissipate the heat from the lamp equally over the lenses.
I would be cautious using it.
The lenses will probably crack or the projector may overheat, lamp burn out, etc.
Try to get a new assembly which is probably very expensive. |
V9079-90001 V9079B TD-SCDMA User 2527s a • 058ats LG • [radial] MIN-13 Series Joemaster • aj-15 HEATHKIT • s a4 t panasonic • Compaq Armada 100S and COMPAQ • cd74hc166 Harris Semiconductor • [bi-polar axial] RMN Series Richey • bsc030n03msg rev1.16 Infineon • RCD 300 PASSAT B6 grundig •
