Yanmar Guest
Posted: Thu Mar 01, 2007 5:27 pm Post subject: Toshiba 53h71 turn off and back on |
I fixed a 53h71 with a new stk 392-150. All works fine but now the tv turn off and on by itself. I found a service bulletin for the same problem but it's for a 50hx70 model... I must add a 47uF from QA01 pin 54 to gnd. Is it the same fix for a 53h71 ? Any idea ?
Thanks
Yanmar |
Posted: Thu Mar 01, 2007 10:46 pm Post subject: |
Solder the jumpers on the signal board. IE the ones around L7711. Try that first. |
Frank Guest
Posted: Thu Mar 01, 2007 11:27 pm Post subject: |
Also Check Power Tact switch |
cory Guest
Posted: Fri Mar 02, 2007 1:09 pm Post subject: |
you should replace 2 convergence ic with original toshiba ics,otherwise you will run into strange problems.try that since other problem was not there before. |
400004 1108UsersGuide Sep88 xerox • Installing-Display-69 apple • LT-32DG8BJ JVC • fdma410nz Fairchild Semiconductor • A24-0520-2 24-26 Keypunches IBM • 5990-8883EN HP • amstrad300 amstrad • PA-952 (A - Nov 2007)(4200-CVU) Keithley • Wiring Diagram Samsung • NSM2-014 NOKIA •
