bozzy2006 Guest
Posted: Sun Mar 11, 2007 9:55 pm Post subject: Philips 42" plasma - Chassis LC4.9E AA - need help |
Model: 42PF5320/10
Blows 4A fuse at powerup - no picture - audio ok.
I need servicemanual or schematics
thanks in advice.
Jesper |
SDS Guest
Posted: Thu Jul 05, 2007 5:04 pm Post subject: Any help? |
Sorry but i don't have shematics either.
I have the same model with the same fault, blows 4A fuse on the left plasma supply board.
Short circuit on the +195V, i tracked it down to the hybrid module IC15 under the biggest heatsink.
On this LG hybrid module (YPPD-J014A) that is hell to get off the board the 2 power transistors Q1 and Q4 are shorted, going by the look of the transistors chips and the diodes next to them i'd say they are both N-MOS, i'll try cutting their silver wires and connecting external isolated transistors attached to the original heatsink as the gate drive does not seem to have burnt out. |
crackjack Guest
Posted: Wed Jul 11, 2007 9:14 am Post subject: Re: Philips 42" plasma - Chassis LC4.9E AA - need help |
bozzy2006 wrote: | Model: 42PF5320/10
thanks in advice.
Jesper |
for this kind of problem. the only sure way to repair is to replace the whole module. |
crackjack Guest
Posted: Wed Jul 11, 2007 9:19 am Post subject: Re: Any help? |
SDS wrote: | Sorry but i don't have shematics either.
yup there is high failure rate on this board called the ysus board. you need to replace the whole board. never tried replacing the IC15. it's better to repair at board level. |
blacky Guest
Posted: Wed Dec 12, 2007 2:20 pm Post subject: Re: Any help? |
yup there is high failure rate on this board called the ysus board. you need to replace the whole board. never tried replacing the IC15. it's better to repair at board level.[/quote]
hi...got the same problem... where to get the whole board.. headache looking in singapore and malaysia.. anybody could help....? |
BEKO chassis 12.7 01 BEKO • dsc1611018ce panasonic • le26-32-37-40-46s81-s86bd bx ch gja26-32 • OS-350 Instrukcja serwisowa . Various • RXA3010 SPEC Yamaha • LH125A,LH125FM Lambda • C221 REVOX • p14 Philips • Tuner RH 300 Siemens • 2sd1426 Inchange Semiconductor •
