s.norris Guest
Posted: Tue Jan 25, 2005 3:49 pm Post subject: rca tv-no power |
tv worked fine went i turned it off.now there is no power but everything else on that circuit works fine. i changed the power cord but still no power.anyone have any ideas.thanks. |
davidmwallace Guest
Posted: Tue Jan 25, 2005 11:46 pm Post subject: RCA 60-inch projection TV - suddenly no power |
What are the chances? The same thing happened to my RCA TV 2 days ago. Worked fine when turned off. The next day: nothing happens when I try to turn it on, either via the remote or by pushing the power button. Checked cable, it is fine. Power outlet works for other devices. Does the entire thing just stop working, or is this common for the power switch to go out? Power switch or something more serious? |
Posted: Thu Jan 27, 2005 2:09 am Post subject: re; rca dead |
Hi Guys, the power supply has failed in your set(s) without the
model & chassis number how do you expect anyone to help you?
you both need to call a qualified tech, Larry E |
eyegriff Guest
Posted: Sun Jul 03, 2005 7:02 am Post subject: Re: re; rca dead |
Anonymous wrote: | Hi Guys, the power supply has failed in your set(s) without the
my model no. is p60923bl |
Posted: Sun Jul 03, 2005 7:12 am Post subject: Re: re; rca dead |
eyegriff wrote: | Anonymous wrote: | Hi Guys, the power supply has failed in your set(s) without the
my model no. is p60923bl | |
guest Guest
Posted: Wed Mar 01, 2006 4:59 am Post subject: My Tv just did the same thing |
What I found was that the fuse was blown, I replaced the fuse plugged it in and once I powered it up I got a bright flash and R14125 burnt to a crisp. it is a 36 ohm 1/4 watt resistor. I found Q14101 was defective it is a IRF740 mosfet I ordered from Newark Electronics and the Low voltage regulator U14101 8 pin ic chip was defective, also ordered from Newark. the part #'s from Newark are IRF740 Mosfet. 06F8399 The Low Voltage reg. is a TDA4605 50B5023. My TV is a 46 inch RCA Projection from 1999 model P46921 chassis PTH195MA.
Hope this helps |
recon0617 Guest
Posted: Fri Feb 12, 2010 9:10 pm Post subject: RCA model 661W20 |
Tv is model # 661W20 it is a 60 inch big screen when you turn it on the power light comes on goes off over and over three or four times then nothing no picture doesnt seem to come on all the way. HELP |
Posted: Fri Feb 12, 2010 11:11 pm Post subject: |
Sounds likethe flyback, clicks 3 4 times and nothing. |
