My Dell 15" E151FPp is dead after 1 day!
Stephen
PostPosted: Tue Feb 01, 2005 1:02 am    Post subject: My Dell 15" E151FPp is dead after 1 day! Reply with quote
Hello.
Can someone please help me.
I have a Dell 15" E151FPp LCD monitor and in its second day of usage, has just died. The power just went from the LCD and the led will not come on at all.
I tried different power cables, nothing.
I opened it up and found the "t2h" 250v fuse had blown so I replaced it with a 3 amp fuse, which blew. I then put in a physically bigger 5 amp and 13 amp fuses, but although the fuses did not blow, the monitor still refuses to turn on.
It seems there's something that's causing it to blow - any ideas as to what it could be? I imagine it's a common enough problem...
Any help at all would be great.
Thanks a lot.
Stephen.
Stephen
PostPosted: Tue Feb 01, 2005 1:07 am    Post subject: Reply with quote
I might add that I have recieved this monitor from a friend who got a replacement for this monitor from Dell, he simply gave this 15" LCD to me to see if i could fix it.
Its only 1 day old in terms of usage.
Thanks
PostPosted: Sat Dec 17, 2005 5:48 am    Post subject: Re: My Dell 15" E151FPp is dead after 1 day! Reply with quote
Stephen wrote:
Hello.
Thanks a lot.
Stephen.
PostPosted: Thu Mar 15, 2007 4:55 pm    Post subject: have you got a solution Reply with quote
I've got the ecact same problem, do you already have a solution????
PostPosted: Fri Mar 16, 2007 4:28 am    Post subject: Reply with quote
Most LCD monitors from dell should carry at least a 2 year warranty. Mine from gateway 3. These are basically considered throw aways. The fuse should be in the primary of the power supply. I would suspect the rectifier, regulator, or a mosfet. You can contact dell and see if they supply just a power supply for the monitor. I doubt it.
PostPosted: Fri Mar 16, 2007 10:46 am    Post subject: Reply with quote
Thanks,
but I've got this monitor because it is broken. I want to use it fore a diy-beamer, so the power supply must be working.
Greetz
