alan G Guest
Posted: Thu May 31, 2007 5:40 pm Post subject: panasonic video repair |
Panasonic video recoreder NVHD650, with K-MECHANISM. Will load tape, and play for approx4-5 seconds then stops. Inserting a tape and then press FF or REW nothing happerns. Capstan motor looks o.k. checked tension and drive belts. Any ideas welcome...... |
Posted: Sat Jun 02, 2007 5:16 pm Post subject: |
Could be loading motor plastic coupler located on the motor shaft under the worm slippng if split. Is a fault code displayed? |
Alan G Guest
Posted: Sun Jun 03, 2007 8:15 pm Post subject: Panasonic repair |
There do not seem to be any problems with the loading, I've checked all codes and none are displayed and all follow the correct sequence when loading a tape. If a tape is inserted, it will load and wait next instruction, if this is FF or REW, the tape unloads to the cassette (as normal) but then nothing happerns. If when loaded the next instruction is to play, then it will for 4-5 seconds then stops, and will not do anything but unload and eject. It's got me.......
Do you still think it could be the loading motor? if so please help, or recommed anything else you may of heard of.
Many thanks. |
