resende Guest
Posted: Sat Jun 09, 2007 3:18 pm Post subject: cuc4400 |
remote control don't work but remote control ok. |
sidney Guest
Posted: Sat Jun 09, 2007 3:37 pm Post subject: |
Remote sensor do go faulty. Check if you got 5 volts on the receiver.
If you have a scope you can check the wave form on the sensor.
Good luck
Sam |
resende Guest
Posted: Sun Jun 10, 2007 5:47 pm Post subject: Re: cuc4400 |
resende wrote: | remote control don't work but remote control ok. |
sesor receiver is fine and he have 5volts. |
Posted: Mon Jun 11, 2007 7:03 am Post subject: |
Check that the clock oscillator of the tv's microcontroller is running at the correct frequency, and check that the signal from the remote receiver really reaches the microcontroller.
If this tv has two microcontrollers, one at the front panel and another at the main chassis, there is probably a insulated link using optocouplers between them (the front panel microcontroller is then not insulated from the mains, as it must run even in standby mode when the main power supply is switched off). In this chase, make sure that the data link works in both directions.
Btw, have you checked that the remote works properly with another similar tv or have you just checked that it sends some kind of output? In the latter case, please check the remote's clock too. Usually it is controlled by a ceramic resonator which may fail. |
resende Guest
Posted: Tue Jun 12, 2007 9:34 pm Post subject: Re: cuc4400 |
thanks people for everything... |
