anita43w
Posted: Thu Feb 17, 2005 8:58 pm Post subject: TOSHIBA - STUCK IN STANDBY |
Hi, I've got two Toshiba RPTV's, 43VJ13P & 42WH18B, both are stuck in standby when switched on, but give them a kick and they come on eventually. Can't be a dry joint as I have blanket soldered. Can anyone help?  |
Larry E Guest
Posted: Thu Feb 17, 2005 11:16 pm Post subject: kick starting your tv |
eventually your leg will get tired of kicking your tv and your brain will
kick in and tell you to call a tech, Larry E |
mark
Posted: Fri Feb 18, 2005 4:40 am Post subject: |
do you literally kick them?
sounds like cold joints/fracure/loose wiring/plugs, ect.
and you have 2 that do that? weird. |
rikki Guest
Posted: Thu Feb 24, 2005 12:41 am Post subject: |
| sounds to me like the teletext board thats faulty if you dont look at teletext just take it out 99% sure thats what wrong |
Posted: Thu Feb 24, 2005 3:18 pm Post subject: |
i have the same problem.
how do i get to the text board?
which one is it!!??
thanks for you help anyone! |
martinkps Guest
Posted: Mon Oct 09, 2006 8:04 pm Post subject: |
I also have the same problem.
can any one tell me how to identify it or where to fin a schematic
advice greatly received |
Posted: Mon Oct 09, 2006 8:13 pm Post subject: |
| If it is not solder joints (you have replaced them all?) check all of the capacitors. (especially the electrolytics) |
Grrrg
Posted: Tue Oct 10, 2006 5:50 pm Post subject: |
| It is very often the teletext module maybe post a photo of the pcb which is most right seen from behind. And then maybe I can tell you which ist the teletext module. |
carcus
Posted: Sun Oct 29, 2006 8:50 am Post subject: |
the early teletext module's on the 42WH18B are very unreliable and go faulty for a passtime .... in fact out of the hundreds of sets i have looked at that it is fitted to this virtualy always the problem for many issues including stuck in standby as well as some other symptoms ...... the newer replacement teletext module is very reliable in fact out of hundreds of set that it's fitted to i have come across the new type has never gone wrong so far....
to proove it's the teletext module without having to buy a new one first, simply unplug it and take it out .... the set will run perfectly ok without the module in ... u'll just have no teletext on analog TV of course |
carcus
Posted: Sun Oct 29, 2006 9:18 am Post subject: |
pic of teletext module
www.lipetsk.name
boom.bg : аукцион -
MondeTech
SEO -
Онлайн поща -
