ghartman
Posted: Sat Jul 21, 2007 6:26 pm Post subject: KLH Bassbite V SubWoofer speaker hummmmmm |
I have this sub woofer from a surround sound system and it hums. I'm guessing its the power amp which is a LM1875T and is a 5 pin unit. Are there any bench tests I can run? Other suggestions? The sub woofer is powered by its own 120 VAC input.
Thanks,
Gary |
Posted: Sun Jul 22, 2007 1:05 pm Post subject: Re: KLH Bassbite V SubWoofer speaker hummmmmm |
ghartman wrote: | I have this sub woofer from a surround sound system and it hums. I'm guessing its the power amp which is a LM1875T and is a 5 pin unit. Are there any bench tests I can run? Other suggestions? The sub woofer is powered by its own 120 VAC input.
Thanks,
Gary |
the problem has many possible cause, but commonly, on power supply section of your amp.it may have a leak filter capacitor. or the groundings is not sufficient. |
speaker! Guest
Posted: Sat Jun 04, 2011 9:43 pm Post subject: how do i fix the humm |
how do i fix the hum on the speaker |
Posted: Wed Dec 23, 2015 1:12 am Post subject: Re: how do i fix the humm |
speaker! wrote: | how do i fix the hum on the speaker |
[/quote]="speaker!"] replace the 2 radial electrolytic capacitors on the power supply board. They are the big ones that are side by side. Mine were 4700 uFD, 25v, 85c. |
Color LaserJet 4600[1].part05 HP • Sigma+M430 +block+diagram++info+pack+12 • AC250I SB-SI 1273657385 LG • 5954-8262 series300techData Sep86 HP • C28-6594-4 PL1 F Programmers Guide Nov68 • SK66-TE-AT MAKITA • PD4213W-H, PD4213W-S, PD4213E-H,PD4213E- • 2sc4423 Sanyo • KV-21C5B Sony • Philips •
