cleanalby Guest
Posted: Fri Aug 03, 2007 2:05 pm Post subject: Sony KP-53S25- intermitant green and red, constant blue crt |
I have a Sony KP-53S25. My problem is that I have a constant blue crt, and the red and green are intermitant, but they both come on and go off togeather. I noticed that when I do an auto channel program, they seem to come on when a channel is detected, or when I change channels. They only come on for a split second and then go back out.
Does this sound like cold solder joints ? Is there anywhere in particular that I need to be looking? I don't have any schematics or manual at all. Are there any free sites that have them ?
cleanalby@yahoo.com
Thanks
Allen |
cleanalby Guest
Posted: Fri Aug 03, 2007 11:02 pm Post subject: Re: Sony KP-53S25- intermitant green and red, constant blue |
| I am also noticeing that whenever I change a channel, the green and red light up briefly. |
Posted: Fri Aug 03, 2007 11:15 pm Post subject: |
| AKB error. Auto kiddy bias. Shut the set off. On the remote press display, the number 5, volume down, then power. Or is it volume up instead of down. Can't remember. See if your getting an error on B+ or.... |
cleanalby Guest
Posted: Sat Aug 04, 2007 1:22 am Post subject: |
| Don't have a remote for it. |
Posted: Sat Aug 04, 2007 4:22 am Post subject: |
| Weird lines, set lights blink, only way to tell is to get the error codes. My guess, one or tubes are bad. Picture sucks??? You can try adjusting the screen control. |
cleanalby Guest
Posted: Sun Aug 05, 2007 12:08 am Post subject: |
| The "BLUE" picture is fine. No weird lines either, just have a completly blue picture. When the green/red fires up they appear to be as bright as the blue tube. If I wanted to check the boards in each gun, would I dissassemble the entire projection assemble, where all three guns are attached, so I don't mess with any of the alignment ? Also I tried removing the board that connects to the tube itself to see if corrosion is the culprit. Did not seem to help, though I do notice that the time in between the blinks is shorter and when they blink, they seem to stay on just a little bit longer. Anyway I wanted to check for cold solder joints and component failure. Is the proper dissassembly method ? Also can you get into diagnostic mode wirh a universal remote or through the console in the front of the tv? I don't have the origonal remote. Thanks Kindly |
Posted: Sun Aug 05, 2007 3:26 am Post subject: |
| Apparently you don't understand. You're on your own. |
Posted: Sun Aug 05, 2007 5:10 pm Post subject: |
| Wow, I'm blown away. I do believe that if I signed up to give people advice on this subject matter, thats what I would try to do, to the best of my ability. Apparently you don't take it serious enough or couldn't be bothered with all the extra typing involved. I also subscribe to what goes around, comes around. You may have very well given one of very dear most loyal admireres, a reason to slam ya. Not to fret, I'm sure that someone else will step up to the plate and demonstrate the proper method for ya. |
Posted: Sun Aug 05, 2007 5:31 pm Post subject: |
| Anonymous wrote: |
Sorry, wrong post here. Hey anonymous, got a name? If your going to post have the balls to put a name behind it. |
Posted: Sun Aug 05, 2007 6:13 pm Post subject: |
| One hit from Sony, no picture has sound. Replace IC301. |
www.lipetsk.name
boom.bg : аукцион -
MondeTech
SEO -
Онлайн поща -
