gruber Guest
Posted: Tue Aug 07, 2007 11:05 am Post subject: Thomson tv chasses tx91 ps dead |
Hi all!
I have a tv to tepair, but I can't solve the problem.
The ps doesn't work at all. I have already changed the Ic (TEA2261) and caps. Diódes and resistors are good. On secunder side there isn't any short. 300 volts is ok. Everything seems to be good, but the ps doesn't work at all. If you know this problem please help. Thanks. Márton |
grubma Guest
Posted: Tue Aug 07, 2007 6:26 pm Post subject: Re: Thomson tv chasses tx91 ps dead |
| (51MT11X) I've solved the problem. C14 470uF/25V |
ibut Guest
Posted: Fri Jun 19, 2009 6:48 pm Post subject: thomson tv tx91 can't wake up from standby mode |
Hi all,
I've problem about thomson tv tx91, can't wake up from standby mode.
do need to change IC ST9293? please anyone give advise!!!
Thanks, ibut |
Posted: Mon Jun 22, 2009 12:29 pm Post subject: |
If the tv has a membrane-style keyboard on the front panel, try disconnecting it and then switch it on by the remote. It is very common on those membrane keyboards of Thomson sets, that they get leaky across one or more switches, and this can cause the microcontroller to lock up.
A common power supply problem in many Thomson chassis is that there are some wire jumpers below the supply transformer, those jumpers can get displaced and cause shorts to the transformer pins, sometimes causing very strange symptoms. |
www.lipetsk.name
boom.bg : аукцион -
MondeTech
SEO -
Онлайн поща -
