Dellish Guest
Posted: Wed Feb 23, 2005 1:19 pm Post subject: Dead Dell 1025HE |
I'm attempting to repair a Dell 1025HE 17" monitor (essentially a Nokia 447S) for a friend.
symptoms: no display - doesnt appear to be scanning, and the HT to the tube seems dead (going by the absence of static when powered up).
Degauss still works, the power LED operates as normal and the power supply seems functional, although a couple of the unregulated rails are running a little low: 15v reads 13.7v and 7v is showing 6v.
I've tested the LOPT out of circuit, and the primary is reading about .2 ohms <- is this a reasonable ball park figure for a healthy component?
There don't seem to be any short circuits within the LOPT from HT to LT side.
I also tested the horizontal ouput transistor out of circuit (BUH1215), which shows ~160 ohms either way across c-e and b-c, but only 1.8 ohm! either way across the b-e junction.
Does this consistute a dead HOT? I know they often include protection resistors/diodes which can skew results a bit when testing.
The cost of replacing the HOT is ~£15 just in terms of the component and delivery, so i'd like to be sure this is whats at fault before ordering up a replacement.
Any help received would be much appreciated. |
njjunior
Posted: Mon May 26, 2008 3:16 pm Post subject: Re: Dead Dell 1025HE |
Dellish:
good day.
Have u solved the problem?
Mine can be worst, as I cant find a flyback to the Dell 1025HE 17" monitor (essentially a Nokia 447S). Old stuff isnt it?
Can u comment on where (homepage eg) I can find it?
Thanks,
Nelson. |
8310 nokia • TAF650ESD Sony • 22RR482 Philips • VA912 SM 1a Viewsonic • bd724 Inchange Semiconductor • CX-JN5-1[1].1.part1 AIWA • BM1912RAM08-D Model DM10 Data Sheet Marc • hfe hr-895 schematics CARVER • ipd50n04s4-10 ds 1 0 Infineon • MRC-A120 2018 Motronix •
