santiago_89
Posted: Mon Aug 13, 2007 9:27 pm Post subject: Measuring the resistance of an RC circuit |
Hi everybody. I'm trying to find the power to gound resistance of a couple of resistive circuits but they each are in parallel with a capacitor. The meter reads a very high value when the cap charges up completely. Is this still a usable reading? Or, to put it another way, will the measured resistance be different if the resistive circuit was shorted? |
kenray Guest
Posted: Fri Aug 31, 2007 12:42 am Post subject: measurement |
once the caps are charged you should be reading the resistance of the resistors. |
Posted: Fri Aug 31, 2007 9:08 am Post subject: |
Yes, in most cases the readout will be correct once the capacitors are charged. However, there are some instruments (only seldom on ordinary DMMs but more common on specialized RCL meters) that either use AC or short DC pulses for the resistance measurements. Those will give a wrong reading when measuring on RC circuits.
You can check it out by several methods:
1) Study the operating manual for the meter.
2) Try measuring the resistance of a single resistor and then connect a capacitor of similar value to your "real" circuits in parallell, check if the reading changes.
3) Check with an oscilloscope if the meter only supplies pure DC or if there are any pulses or AC components superposed on it. |
FL8385 Harman/Kardon • 3ncForeword NOKIA • lg flatron l1810b lb800k ch cl-42 LG • [snap-in] HPR Series Zonkas • philips chassis tpm6.1e la [ET] Philips • vr1500 201 Philips • 20B-SC SHARP • SANG TCD-1389USB SANG • DSO 1604/1602 Gould • mmbt918l Motorola •
