bertboye Guest
Posted: Sat Sep 01, 2007 7:03 pm Post subject: faulty fujitsu monitor |
i have a fujitsu siemens 900P computer monitor when I switch it on the screen comes on for an interval of a second then the screen goes black. the power led stays lit when it does this. when i switch the monitor off then on the screen comes back on then off in exactly a second. is this a major problem and how would it be fixed any help appreciated |
bbp12 Guest
Posted: Tue Sep 04, 2007 7:58 am Post subject: |
You have aproblem major which you are unlikely to fix- find an experienced repairer. |
Posted: Thu Sep 13, 2007 4:50 am Post subject: |
It is an LCD monitor ? |
niv16 Guest
Posted: Sat Sep 15, 2007 1:49 pm Post subject: faulty fujitsu monitor |
I have exactly the same monitor and exactly the same problem. It seems to be an issue with the connectors in the cable, because sometimes when you wiggle the cable around at the back of the PC, the picture stays on a bit longer. However, as the cable goes into the monitor at the back, I'm unable to replace it. I hope you have warranty (I don't) - use it. |
jus004 Guest
Posted: Thu Nov 22, 2007 5:32 pm Post subject: Re: faulty fujitsu monitor |
check the tube base board(on the neck of the tube) for dry contacts. you may have to remove the metal shielding first to check. Be careful not to put too much pressure on the socket as the tube neck can crack very easily. Hope this will help. |
LMG7525RPFF LMG7525RPFF • Revox B285-B286 Serv REVOX • philips 21pt1663 chassis l7.2e aa Philip • buk9523-75a buk9623-75a Philips • for10c NOKIA • hfe mcintosh mi350 service 10r01 on Mc I • carkit NOKIA • tx14b3tf z375 198 panasonic • HP 5328a Agilent • cdtrans NOKIA •
