Fahlstrom Guest
Posted: Tue Jul 06, 2004 3:14 pm Post subject: Hp L1702 Monitor |
Posted: Sat Dec 13, 2003 9:22 pm Post subject: Hp L1702 Monitor
I have a Hp 1702 LCD Monitor wiith a broken 15-pin vga cable , now i need pinout and color schematic . I have 10 cables sticking out of the monitor and haven't a clue what to do . Please help or send me schematic .
Here comes the color and value of my cables out of the monitor :
Brown = 9,6 v
Green = 0 v
Yellow = 1,4 v
White = 1,4 v
Orange = 9,6 v
Black = 0,9 v
Red = 9,9 v
I have allready connected Rgb , that was he easy part .
Can anyone tell me which color is h-sync , v-sync and the rest ... |
Tomi Guest
Posted: Tue Jul 06, 2004 3:15 pm Post subject: |
I do not have specific information concering this monitor.
The colors on the monitor cables are not widely standardized,
so different monitors can use different colors for different
functionality.
The following document might be worth to read:
Identifying connections on unknown or cut monitor cables
http://www.epanorama.net/documents/pc/svga_wiring.html
It has information on locating the sync signal on cut or broken
monitor cables.
Few comments on your monitor measurements:
I would not connect anythign from the VGA card to the wires that
have those over 9V voltage. This high voltages are higher than
any VGA signal uses (all VGA signals are less than 5V) and connecting
this high voltages to PC grahics cards can damage it.
It sounds strange that any VGA cable signal has this high voltages. |
Gert Guest
Posted: Tue Jul 06, 2004 3:16 pm Post subject: |
here is the color codes:
PIN LABEL FUNCTION COLOR
1 RED Red color signal pink
2 GREEN Green color signal grey
3 BLUE Blue color signal blue
4 ID2 Monitor identification bit 2 n.c.
5 N.C. Not Connected white
6 GND-RED Ground Red signal gnd red
7 GND-GREEN Ground Green signal gnd green
8 GND-BLUE Ground Blue signal gnd blue
9 N.C. Not Connected red
10 GND-SYNC Ground Sync signal gnd.black
11 ID1 Monitor identification bit 1 n.c.
12 ID0 Monitor identification bit 0 brown
13 H-SYNC Horizontal Synchronization orange
14 V-SYNC Vertical Synchronization yellow
15 N.C. Not connected green |
netforce Guest
Posted: Wed Aug 18, 2004 11:42 pm Post subject: L1702 same problem |
hi i got the same problem as you can you mail or add me to your msn [email protected] ASAP.
we can help eachother
greetings, netforce |
Lanne Guest
Posted: Sun Oct 03, 2004 8:37 pm Post subject: Re: L1702 same problem |
are all the cables with "n.c." not connected? How is it with the thicker blue, red and gray cables (with smaler cables inside)? It would be great if you have some answers. Or even better the schematics.
Please respond to: [email protected]
Thanks / Anders |
kim Guest
Posted: Sun Apr 17, 2005 6:13 pm Post subject: Re: Hp L1702 Monitor |
Brown = 9,6 v
Green = 0 v
Yellow = 1,4 v
White = 1,4 v
Orange = 9,6 v
Black = 0,9 v
Red = 9,9 v
Can anyone tell me which color is h-sync , v-sync and the rest ...[/quote] |
Iwan73 Guest
Posted: Mon Apr 21, 2008 10:23 am Post subject: Easy solution for fixing |
Hello all,
The pinout that already being posted is correct.
U can buy a VGA extension cable and cut 1 side off.
Open ur monitor and disconnect the connector inside for de VGA cable.
Now u have to open the connector u have cut off from the cable to see how the wires are connected.
Now u can re-attach the wires carefully trough figuring out on witch pin the wires are connected to.
The most extension cables come close with the collors.
My fix was as follow:
Connector Cut extension cable
Pin 1 Pink-inside Red wire Red wire
Pin 2 Grey-inside Grey wire Grey wire
Pin 3 Blue-inside Blue wire Blue wire
Pin 4 Not connected Black
Pin 5 White Black
Pin 6 Grnd-inside Red wire Grnd
Pin 7 Grnd-inside Grey wire Grnd
Pin 8 Grnd-inside Blue wire Grnd
Pin 9 Red White
Pin 10 Black Black
Pin 11 Not connected Not connected
Pin 12 Brown Brown
Pin 13 Orange Green
Pin 14 Yellow White
Pin 15 Green Yellow
I hope this will provide the answer your looking for?
Grzzzzz,
Iw@n |
2sd882 UTC • 02-nhl4jx-parts NOKIA • chassis KS3A Samsung • irfz48n Inchange Semiconductor • Atlas 10K V maxtor • DK RELAYS Keithley • stgb35n35lz stgp35n35lz ST • RX330 Pioneer • bss110 Philips • GX-255 Akai •
