Posted: Thu Sep 27, 2007 2:23 pm Post subject: Solar panel Project help request! |
Hi there,
First things first, I’d like to say this looks to be a great forum. There are some very interesting topics on here, and some very clued up people giving out priceless advice. Hopefully I’ve come to the write place.
I am currently in my final year at Manchester Metropolitan University studying for a degree in mechanical engineering. For my final year project, I have been given the task of coming up with some kind of back up system for a household immersion heater. This system must “green” powered using an array of solar powered photovoltaics (PV).
In the aim of getting a good mark, I’ve decided to look into installing a small DIY system to my home for testing purposes. But have come across a major stumbling block as I can’t seem to find a heating element or device that can be powered using such a low wattage give off from a small solar panel. I’ve searched high and low but have had no luck. I was wondering if any of the geniuses on here could point me in the direction.
Any help would be very helpful and much appreciated,
Thank you,
Stuart
wolfdogg
Posted: Mon Oct 01, 2007 8:47 pm Post subject: |
certainly,
your wattage can be derived from battery banks. the panel just charges the banks on a daily basis. The battery bank, however big you need calculated by teh amp hour ratings, will supply the power, not the panel. the panel just charges teh batteries and the size of which is determined by the size of the battery bank.
what kind of power is required?
what is an immersion heater? _________________ Rusty Electronic Tech;
been thru electronic engineering in college, top of class grades, 10 years ago. some field exp. |
wolfdogg
Posted: Mon Oct 01, 2007 8:50 pm Post subject: |
certainly,
your wattage can be derived from battery banks which also allows 24 hour operation reducing dependency on the sunlight. the panel just charges the banks on a daily basis weather permitting. The battery bank, however big you need calculated by teh amp hour ratings, will supply the power, not the panel. the panel just charges teh batteries and the size of which is determined by the size of the battery bank.
what kind of power is required? _________________ Rusty Electronic Tech;
Poblizo.com : ïúòåøåñòâèÿ
KONKA • [radial thru-hole] CD269 Series Chirx • Philips L3F16T Philips • CM 10 cherokee • VP930-1 Series SB 009 Viewsonic • mitsubishi ct-25m5bt MITSUBISHI • hfe onkyo tx-sr605 sa605 sa8560 ONKYO • 22sa1256 2 • Panel CHIMEI INNOLUX N156BGE-L11 4 [DS] • TD-220 T Zanussi •
