Posted: Sun Mar 06, 2005 9:42 pm Post subject: Sony CCD-TRV99 C:31:00 ERROR |
When I try to play or record on a tape it gives me a C:31:00 error code. Your help would be greatly appreciated.
thanks |
Vong Guest
Posted: Tue Mar 21, 2006 7:38 am Post subject: Sony ccd-trv99 error code |
| I am having code 32:20, 31:20, or 31:00 in both record and play back including tape stuck but not every time, after turn off on on again sometime goes to work fro a while. Would you please help. |
Posted: Thu Mar 23, 2006 1:17 pm Post subject: |
Hello replace A7018245B for fix your camcorder.
Regards, Niko. |
Victor, H Guest
Posted: Sun Nov 05, 2006 2:38 am Post subject: Sony DCR-HC 42 touch screen |
My sony HC-42 is a year and half old, used very little and store in the my office draw. One day, I turn on my touch screen does not works but by remote only. Wich it mean I could not change any thing even Date. Please help.
Victor, H  |
Posted: Wed Oct 14, 2009 12:32 pm Post subject: Re: Sony CCD-TRV99 C:31:00 ERROR |
HI, DONT HIT YOUR CAMERA! I KNOW WHAT CAUSES THIS PROBLEM AND ITS EASY TO SORT OUT.
THE C31 ERROR CODES AND ALSO CASSETTE DOOR NOT OPENING PROPERLY IS USUALLY CAUSED BY A VERY FINE RESIDUE BUILDUP ON THE BATTERY TERMINALS AND THE ONES ON THE CAMERA AND ALSO THE MAINS SOCKET. THIS IS CAUSED BY DAMP,HUMID OR WET CONDITIONS. YOU NEED TO TAKE A VERY SMALL METAL OBJECT LIKE A NAIL FILE ETC AND SCRAPE ALL TERMINALS CLEAN AND THAT SHOULD DO THE TRICK. IT WORKED ON MY SONY CCD-TR515E CAMCORDER. KEITH
| Anonymous wrote: |
thanks |
Posted: Thu Nov 26, 2009 6:43 am Post subject: |
Self-diagnosis Code Table (for CCD-TRV99)
Repaired by | Block Function | Detailed Code | Symptom/State | Correction.
_____C___:|_____21_____:|_____00_____| Condensation_| Remove the cassette, and insert it again after one hour.
C : Corrected by customer
H : Corrected by dealer
E : Corrected by service engineer
C 2 1 0 0 Condensation. Remove the cassette, and insert it again after one hour.
C 2 2 0 0 Video head is dirty. Clean with the optional cleaning cassette.
C 2 3 0 0 Non-standard battery is used. Use the InfoLITHIUM battery.
C 3 1 1 0 LOAD direction. Loading does not
complete within specified time
Load the tape again, and perform operations from the beginning.
C 3 1 1 1 UNLOAD direction. Loading does not
C 3 1 2 0 T reel side tape slacking when unloading. Load the tape again, and perform operations from the beginning.
C 3 1 2 1 S reel side tape slacking when unloading. Load the tape again, and perform operations from the beginning.
C 3 1 2 2 T reel fault Load the tape again, and perform operations from the beginning.
C 3 1 2 3 S reel fault Load the tape again, and perform operations from the beginning.
C 3 1 3 0 FG fault when starting capstan Load the tape again, and perform operations from the beginning.
C 3 1 3 1 FG fault during normal capstan operations Load the tape again, and perform operations from the beginning.
C 3 1 4 0 FG fault when starting drum Load the tape again, and perform operations from the beginning.
C 3 1 4 1 PG fault when starting drum Load the tape again, and perform operations from the beginning.
C 3 1 4 2 FG fault during normal drum operations Load the tape again, and perform operations from the beginning.
C 3 1 4 3 PG fault during normal drum operations Load the tape again, and perform operations from the beginning.
C 3 1 4 4 Phase fault during normal drum operations Load the tape again, and perform operations from the beginning.
C 3 2 1 0 LOAD direction loading motor time-out
Remove the battery or power cable, connect, and perform operations
from the beginning.
C 3 2 1 1 UNLOAD direction loading motor time-
out
from the beginning.
C 3 2 2 0 T reel side tape slacking when unloading.
from the beginning.
C 3 2 2 1 S reel side tape slacking when unloading.
from the beginning.
C 3 2 2 2 T reel fault
from the beginning.
C 3 2 2 3 S reel fault
from the beginning.
C 3 2 3 0 FG fault when starting capstan
from the beginning.
C 3 2 3 1 FG fault during normal capstan operations
from the beginning.
C 3 2 4 0 FG fault when starting drum
from the beginning.
C 3 2 4 1 PG fault when starting drum
from the beginning.
C 3 2 4 2 FG fault during normal drum operations
from the beginning.
C 3 2 4 3 PG fault during normal drum operations
from the beginning.
C 3 2 4 4 Phase fault during normal drum operations
from the beginning.
E 6 1 0 0 Difficult to adjust focus
(Cannot initialize focus.)
Inspect the lens block focus reset sensor (Pin !» of CN551 of VC-195
board) when focusing is performed when the focus dial is rotated in the
focus manual mode and the focus motor drive circuit (IC552 of VC-195
board) when the focusing is not performed.
E 6 1 1 0 Zoom operations fault
(Cannot initialize zoom lens.)
Inspect the lens block zoom reset sensor (Pin @Á of CN551 of VC-195
board) when zooming is performed when the zoom lens is operated and
the zoom motor drive circuit (IC552 of VC195 board) when zooming is
not performed.
E 6 2 0 0 Handshake correction function does not
work well.(With pitch angular velocity
sensor output stopped)
Inspect pitch angular velocity sensor (SE451 of SE-74 board) peripheral
circuits.
E 6 2 0 1 Handshake correction function does not
work well.(With yaw angular velocity
Inspect yaw angular velocity sensor (SE452 of SE-74 board) peripheral
circuits.
Service Mode Display
The service mode display shows up to six self-diagnosis codes shown in the past.
Display Method
While pressing the “STOP” key, set the switch from OFF to “VTR or PLAYER”, and continue pressing the “STOP” key for 5 seconds
continuously. The service mode will be displayed, and the counter will show the backup No. and the 5-character self-diagnosis codes.
Switching of Backup No.
By rotating the control dial, past self-diagnosis codes will be shown in order. The backup No. in the [] indicates the order in which the
problem occurred. (If the number of problems which occurred is less than 6, only the number of problems which occurred will be shown.)
[1] : Occurred first time [4] : Occurred fourth time
[2] : Occurred second time [5] : Occurred fifth time
[3] : Occurred third time [6] : Occurred the last time
End of Display
Turning OFF the power supply will end the service mode display.
Note: The self-diagnosis display data will be backed up by the coin-type lithium battery. When this coin-type lithium battery is
disconnected, the self-diagnosis data will be lost by initialization.
example: 3C:31:11
3=backup number
C=repaired by (customer)
31=block (reload the tape)
11=detailed code (UNLOAD direction. Loading timed out) |
Gonda Gabriel Guest
Posted: Sat Nov 04, 2017 5:40 am Post subject: My Sony radio display C 31 00 |
Please,
Assist my system does not work properly |
Poblizo.com : ïúòåøåñòâèÿ -
f217tune LG • LCD tv LC4.3HE AA Philips • SM 312278513321 EN.part3 Philips • FX-880 Part List epson • JW EDN p3 Fluke • Viore PDP42V18HA VIORE • Panel CHIMEI INNOLUX V546HK3-PS1 0 [DS] • HCD-MX500i_HCD-MX550i SONY • Kyocera FS-1010 Parts Manual Kyocera • 422 Tektronix •
