floydturbo
Posted: Tue Oct 23, 2007 3:50 pm Post subject: Denon avr-1604 +45volts at all output transistors |
Unit goes into standby. It appears that all output devices are fine, but 45volts +/- at output due to high voltage at each of the transistors. Why would all they all see such high input voltage to the transistor?? |
Posted: Tue Oct 23, 2007 9:20 pm Post subject: |
When the outputs are infact ok, the plus/minus rails present at the outputs are either the loss of bias control(latched circuitry) OR it may be leakage back through the protection circuitry. Depending on the design/device used, you should at least read a balance of +_ .5 to 1.5 V at the base of txixtors.
Common bias control problem are open (low value) rsistors supplying the said circuitry---unless have experience & can spot check w/out documentation, need to get a schematic. |
