RCAguy
Posted: Sat Oct 27, 2007 6:42 pm Post subject: RCA TV makes high pitch noise, no picture/sound |
My RCA 32” CRT TV has no output (sound or video) and makes a high pitch noise when plugged in, pressing buttons have no effect. Any idea onto what could be the problem?
TV info:
RCA Oct 1998
model: F32632SB
32" screen
Another picture
Another picture
Posted: Sat Oct 27, 2007 10:05 pm Post subject: |
Check Q4401 to see if it's shorted, resolder cold solder on t4301. |
Posted: Sat Oct 27, 2007 10:31 pm Post subject: |
Also resolder L401near the q401 |
RCAguy
Posted: Sun Oct 28, 2007 6:31 pm Post subject: |
Another bit of information, the TV did POP when it first did this. Does that help?
I could not find Q4401 but did find both L401 and q401, but they both look OK. I looked closely at the whole underside of the mainboard and did not see anything that looked like a short or damaged solder.
I included some more pictures I took…
ummm, ignore the carpet... >_> |
Posted: Sun Oct 28, 2007 6:34 pm Post subject: |
RCA labels it as Q14401 so it would be Q401. You need to take a meter and check it. A visual inspection won't do it. |
Frank Guest
Posted: Sun Oct 28, 2007 11:22 pm Post subject: |
Is this a ctc chassis what #? plug in and put you meter in volts DC and put the probes across the big cap,should be about 160v the move just the positive prove to the colector of the Q401 should be a little more.give results. |
arturo011
Posted: Tue Oct 30, 2007 3:49 am Post subject: |
Your TV SMPS is not oscillating at the right frequency and that is causing the whining sound from the SMPS transformer.
you will need to check the horizontal output transistor, there is also something called the flyback feedback driver transformer(it is a small transformer usually blue in colour and looks like an IFT. |
