markdon Guest
Posted: Sun Oct 28, 2007 4:37 pm Post subject: tv plugged into wrong voltage, any fix? |
Hi
I stupidly plugged an ntsc tv from Japan into a british socket and now there seems to be no life in the tv at all, i know the ntsc picture wont work with british pal signal but i wondering if it was possible to find out what the problem would be and if it is possible for a tv repair shop to repair and test a japanese tv.
thanks
Mark |
cory Guest
Posted: Sun Oct 28, 2007 5:41 pm Post subject: |
if you plugged in 120 volt tv into 220 volt outlet it will blow power supply.should be fixable by repair shop.after you need to get a unit to change 220-120 volts. |
markdon Guest
Posted: Sun Oct 28, 2007 6:25 pm Post subject: |
ok thanks |
mpsw13 mpsw14 Motorola • 062aev LG • CUC-1828 Grundig • ntmsd6n303r2-d ON Semiconductor • x amp CARVIN • ES140-TE-AT MAKITA • 2sb852k Rohm • ENA-TDR 100Base-Tx Ethernet Cable MOI re • HP 181A 252C 181AR Operation Agilent • dhd550g dwu550g dwx600g dhd600g dwu600g •
