Posted: Sun Oct 28, 2007 11:07 pm Post subject: Sony KV-27TS27: Excessive White |
I have a Sony KV-27TS27 (SCC-E54A-A chasis) that had poor colors (whites that were black, reds that were blues in some spots, etc) when using the VHF / UHF input on the back. The RCA video input worked perfectly so I suspected the tuner to be the culprit.
Not knowing much about diagnosing TV's I consulted to another forum in which someone suggested resoldering T01, T02, and T03 in the IF module (IF model# 1-464-756-21), as well as replacing all 4 caps.
Now the TV has excessive white (on both RCA and VHF / UHF inputs), and no sound, unless the sound inputs on the back are used. Their is still a picture, but it is very faint with all the white. I replaced the original caps one by one but have the exact same results. I also triple checked all solder connections made, and am confident they are all good.
I suspect the heat from the soldering iron might have damaged one of the coils, but am unsure if my symptoms correspond with an IF module problem.
do my symptoms match a problem with the IF module?
was my original color problem probably related to the tuner?
any help greatly appreciated, TIA! |
tip3055 Inchange Semiconductor • cp 600 dlp 32d1lps 158 Daewoo • Wren VI HH Brochure Nov88 cdc • NP6012PC CANON • PHILIPS Q522.1E LB CHASSIS LCD TV SM Phi • Panel SAMSUNG LTA320AA05 0 [DS] . Variou • BENQ- E61 1 siemens • B53-0138-00-TXT Kenwood • 2sd2120 Sanyo • VZ8 Chassis MITSUBISHI •
