watkins
Posted: Fri Nov 02, 2007 4:41 pm Post subject: Kenwood RD-K501usb compact hi-fi |
i am in trouble with this compact hi-fi , no schematic found on the net .Failure :
some time in random time the device switch OFF and again ON without any apparently reason.It can work for 7 hours without problems and some time go in fail mode and again come back in normal function but never in permanent way.
I exclude bad solder joint or intermittent contact or overheating.In my opinion is a false power supply protection that cause fault :
does any body had similar problem with or there is a design fault ?
thanks for cooperation
francesco |
Posted: Fri Nov 02, 2007 10:06 pm Post subject: |
Intermittent problems such as your description-- can be a real pain to spot. Doubt if it is related to a "design flaw". Are there any mechanical switches of any kind involved in operation of the unit? ---possibility? As far as protection, with the help of schematic, you can monitor any protection line.
In general, while there is always a possibility of electronic device failure, in consumer electonics, mechanical issues such as mode select &/or sense switches are usually the root cause of intermittent functions. |
Posted: Sun Nov 04, 2007 7:55 am Post subject: Re: Kenwood RD-K501usb compact hi-fi |
| watkins wrote: |
francesco |
--HI---THAT ASIMPLE PROBLEM CAN U CHECK YOUR SPEAKER WIRING IT MIGT THERE HAD SHORT AND CHECK POWER AMPLIFIER IF THERE A HUMMING..IF HAVE CHECK YOUR POWER OUTPUT IC OR TRANSISTOR AND TRY TO PUT OTHER SPEAKER UNIT..BECAUSE IF A DEFECTIVE SPEAKER CAN CAUSE OF POWER PROTECTION MODE--THANKS FROM TEPHIL...EX KENWOOD TECHNICIAN-MHER |
Zvone Guest
Posted: Fri Jul 04, 2014 9:03 am Post subject: |
its faulty 32.768 crystal, marked X11 on the top board
gl replacing it |
Panel CHIMEI INNOLUX V650HP1-LS6 0 [DS] • hfe philips bd663a service de Philips • 2n3819 2 Vishay • Samsung BN44-00428B PSU Schematic.pdf sa • Beko 12.4-12.5 BEKO • d45h5 d45h8 d45h11 . Electronic Componen • 60PB6500+TV+LG LG • 2sk2866 Toshiba • ts ec 2 panasonic • 11AK30 A4 Vestel •
