jeandino Guest
Posted: Mon Mar 14, 2005 9:37 am Post subject: Sony CMT-CP101 |
I have a audioset from Sony type CMT-CP101, this set gives almost no sound at the maximun volume. Is there somebody now`s the problem.
Thanks, Rene. |
rocco Guest
Posted: Sat Apr 09, 2005 12:43 pm Post subject: Re: Sony CMT-CP101 |
jeandino wrote: | I have a audioset from Sony type CMT-CP101, this set gives almost no sound at the maximun volume. Is there somebody now`s the problem.
Thanks, Rene. |
I have the same trouble with my sony CP101. Did you find the cause?
Regards |
Don Pivo Guest
Posted: Mon May 16, 2005 6:11 pm Post subject: |
Hello,
my CMT-CP101 suffers n the same desease.
please help !
regards |
Posted: Tue May 17, 2005 3:08 pm Post subject: |
Hello,
i found something: there is an irish site offering the Q330 transistor which is obviously responsible for " Power on Muting" on the CP101 mainboard. its Partnumber is KRC103S (please google !).
the only thing is, that they charge 12,50 Euro for shipping to europe.
may that SMD transistor be the cause to our problems?
regards. |
breagan Guest
Posted: Fri May 27, 2005 10:15 am Post subject: cpt101 |
Q 330 is the muting transistor (KRC103) which goes faulty also change the jumper wire JW307 to a 470 ohm carbon resistor |
Posted: Sun May 29, 2005 9:07 am Post subject: |
Thank you very much for the information.
Do you know where to get the transistor from?
best regards.
(dsf.schmidt$web.de) |
bluerobboman Guest
Posted: Tue Aug 09, 2005 10:20 am Post subject: sony cmt cp101 low audio levels |
Hi all,
First of all I confirmed that the Q330 power on muting transistor was at fault by substituting it with one of two others on the PWB namely Q308 CD on switch or Q304 Tuner On switch. The former restored full o/p power whilst the CD could not now be enabled. Static checks showed Q330 Base o/c having downloaded the data sheet for KRC103S I noted the device I removed was not marked correctly on inspection prehaps an equivalent ? Now to the interesting bit, being in the industry what a hard component to find ! That is if you don't wish to pay an extraodinary ammount from a certain Irish component supplier. Best results so far outside of SONY of course is a firm called Vision Aids KRC103S @ £3.44 each plus £2.00 P&P + VAT, Another option altough not tried out, is a pre biased transistor made by Diodes Incorporated in the Digi-key catalogue part number DDTC124ECADICT-ND @ £0.23 each plus P&P + VAT. looking at the circuit I personally cannot see any reason for such a high number of these devices to fail i.e. stress etc. Hope some of this helps Regds Rob. |
dar Guest
Posted: Thu Oct 27, 2005 9:01 pm Post subject: Re: sony cmt cp101 low audio levels |
I read this on Wednesday, ordered the transistor on-line as suggested, got the part this morning, replaced the transistor one hour ago. Sound fully restored - Thank you bluerobboman!
bluerobboman wrote: | Hi all,
First of all I confirmed that the Q330 power on muting transistor was at fault by substituting it with one of two others on the PWB namely Q308 CD on switch or Q304 Tuner On switch. The former restored full o/p power whilst the CD could not now be enabled. Static checks showed Q330 Base o/c having downloaded the data sheet for KRC103S I noted the device I removed was not marked correctly on inspection prehaps an equivalent ? Now to the interesting bit, being in the industry what a hard component to find ! That is if you don't wish to pay an extraodinary ammount from a certain Irish component supplier. Best results so far outside of SONY of course is a firm called Vision Aids KRC103S @ £3.44 each plus £2.00 P&P + VAT, Another option altough not tried out, is a pre biased transistor made by Diodes Incorporated in the Digi-key catalogue part number DDTC124ECADICT-ND @ £0.23 each plus P&P + VAT. looking at the circuit I personally cannot see any reason for such a high number of these devices to fail i.e. stress etc. Hope some of this helps Regds Rob. | |
Ile Finland Guest
Posted: Fri Oct 28, 2005 8:26 am Post subject: Sony CMT-CP101 |
No sound at the maximun volume:
Replaced Q330 KRC103S is same as DTC124EK
and change JW370 jumper wire to 470ohm carbon resistor (475ohm).
That`s it! |
[email protected] Guest
Posted: Sat Oct 29, 2005 6:37 am Post subject: Sony CMT-CP101 steroe system |
Hi, I am Otto, Danish living in Cyprus. Pretty pissed off by same problem, i.e. no output some of the time. Try switching functions, some times it helps, i.e. tape/MD etc. Sony is pissing us off with inferior components, I don't think it has anything to do with the outpuit moodule, it must be the switch thet reallocates channels from different inputs, think Sony should come up with an eplanation on why and how to remedy...
Otto |
2n5611 Semelab • mje13005 Inchange Semiconductor • hfe perreaux industries ep schematics PE • Pioneer • 2sd1778 Inchange Semiconductor • f200cd LG • 715G6338+PSU Philips • satellite 2400 2405 TOSHIBA • an 1200-5 HP • Panasonic TX-49FXW584 Chassis LA76 [X] p •
