BBM
Posted: Wed Dec 05, 2007 10:46 pm Post subject: intermittent vertical scan collapse |
Mitsubishi Diamond pro 930
Does anyone have a service manual for the tube, iirc it is the same one that was used in the 19" lacie electron. |
Posted: Wed Dec 05, 2007 11:14 pm Post subject: |
Resolder the vertical IC and the Diode that connects to it. |
Posted: Mon Dec 10, 2007 8:02 am Post subject: |
A common cause for vertical scan faults in monitors is bad solder joints on the scan coils PCB. In particular, if solder lugs are riveted to the PCB and the sharp edges of the rivet heads cut through the copper foil, there can be nasty intermittent contacts that are not so easy to see at first instance.
A definite sign of that the vertical scan coil has gone open circuit is if, when you check the voltage at each end of it with an oscilloscope, you find a square wave of about 30 V p-p at one end and zero at the other end. |
PCZ0903046CE panasonic • dsd1406006ce panasonic • vl-wd250e Sharp • H500 ZENITH • khb9d0n90n1 KEC • DV-260-S Pioneer • MQMSH0011DG151214REV1 AX800 Series SOS O • PRX Series Interface PCB Parts List JBL • service Daewoo • PM300 pwr amp Carver •
