polaret
Posted: Wed Dec 12, 2007 6:43 pm Post subject: daewoo l i1911mn |
I have this monitor and after 10-15 minutes the picture disapears at first flashing and then black when i reconnect the PC gives sign no signal
can any one help |
Neil Kwyrer Guest
Posted: Thu Dec 13, 2007 8:26 am Post subject: Daewoo monitor |
There is a fault in your monitor- it could be anything- the point is that you are seeking a simple answer to a complicated question(as do many)- the bottom line is that experience & knowledge are needed to fix the fault- you don't have- find a good tv tech. |
polaret
Posted: Thu Dec 13, 2007 4:45 pm Post subject: |
I am a tv tech but i have never take that kind of monitor, with that kind of damage, i have change all the capasitor and the first problem solved that is the second one .
If someone have ever that kind of pro it could be usefull, thats why you make a post, we are not seeking for a smart guy but for smart answers |
Posted: Thu Dec 13, 2007 5:27 pm Post subject: |
Not familiar with the specific monitor but , sounds like it may be a "thermal" issue? ---may be try using a component cooler on the circuit?
In general, the "no signal" message is triggered when there is no video synch detected &/or lost from the detection circuitry which can be inside of a signal process IC. Anything from a connection issue or malfunction in synch. processing can cause it. If you can find a schematic & scope the signal, should give you some ideas. |
polaret
Posted: Thu Dec 13, 2007 5:48 pm Post subject: |
Maybe i was not explicit , the problem is not that says <no signal> but the picture goes down (black)after flashing .
when the picture is black i disconnect the PC and appears <no signal> maybe some dry joints or proseccor internal fault ,but i have no diagram to seek for
vtech thanks anyway |
DiamondMax 22 SATA II maxtor • toshiba d-vr7kc sm TOSHIBA • 2MD-001 Kyocera • LeXfiles SXFun6in1v1.2 Aug2004 Philips • AVR3801 Denon • R3265A R3271A Spectrum Analyzer Vol II S • AXIAL TAPING, Cut Lead & Lead Forming an • pdtc144e series Philips • General EP4000 096 Minolta • LC7.2E LA LCD TV.part06 Philips •
