whiteboy Guest
Posted: Thu Dec 01, 2005 1:40 am Post subject: balanced versus unbalanced |
Hello
my power-amplifier has unbalanced inputs (XLR) but my pramp has normal balanced outputs (cinch).Can these two be connected without problems?What is the difference between balanced and unbalanced?
Thaks for your help
Yvan |
electronicsuk
Joined: 02 Dec 2005 Posts: 2 Location: United Kingdom
Posted: Fri Dec 02, 2005 3:27 am Post subject: |
The balanced connections use a shielded twisted pair cable, the two twisted conductors carry the original signal and a copy of the signal 180 degrees out of phase. At the receiving end the two signals are combined and any interference picked up equally by both conductors is cancelled out.
Balanced connections are found more on professional audio equipment and are preferable to unbalanced. For an unbalanced to balanced connection, wire the the hot conductor on the unbalanced side to XLR pin 2, and the ground conductor from the unbalanced side to XLR pins 1 and 3. Be aware that this wont be a proper balanced connection, for that to work you need balanced connections at both the send and receive end.
Also worth noting that I think you got balanced and unbalanced the wrong way round, XLR carries balanced signals. That's it, in a nutshell! _________________ "I know it's hard for you to put food on your family" |
letmein Guest
Posted: Mon Dec 17, 2007 12:46 pm Post subject: heater |
is anybody knows how to operate japanese toshiba aircon??? I m trying to get heat but it is cooling my room.....please help urgent |
Compact C 1100 Quadrosound ELAC • R3 Yamaha • aiwaadcm60 AIWA • HR2440F-TE MAKITA • hfe 300 series 2 service en PHASE LINE • 2sb1690 Rohm • lz G-Luxon • 7002_9002 KTC • tip115 Samsung • 2sc4411 Sanyo •
