ksoehn Guest
Posted: Tue Dec 18, 2007 10:39 pm Post subject: Television troubleshooting |
30" HDTV CRT TV set (2003). No onscreen static charge or video-audio. Standby light blinks 6 or 7 times (depending on which time it is plugged in) hesitates, then repeats. There is a typical power up thrum when it is first plugged in. I have found sites which suggest low voltage of some kind precipitates such an indication. I have a multimeter but don't have a service manual, so don't know where to test for low voltage levels. I have found sites which suggest a control IC may be responsible, but don't know where to find it; is it a plug-in or solder-in chip? What would be the likely components, in order of cost, to try replacing for such a problem? Does anyone have a PDF of a service manual for this model? |
Posted: Tue Dec 18, 2007 11:38 pm Post subject: Re: Television troubleshooting |
ksoehn wrote: | 30" HDTV CRT TV set (2003). No onscreen static charge or video-audio. Standby light blinks 6 or 7 times (depending on which time it is plugged in) hesitates, then repeats. There is a typical power up thrum when it is first plugged in. I have found sites which suggest low voltage of some kind precipitates such an indication. I have a multimeter but don't have a service manual, so don't know where to test for low voltage levels. I have found sites which suggest a control IC may be responsible, but don't know where to find it; is it a plug-in or solder-in chip? What would be the likely components, in order of cost, to try replacing for such a problem? Does anyone have a PDF of a service manual for this model? |
You think anybody here has cristal balls?read well you post for help and you know what i mean? |
[radial] ME-PX Series 2-2 Suncon • DVR530-630 Pioneer • SGH F480 Samsung • [SMD] ZR Series Nichicon • Deltec Precision Audio P-400 schematic D • Panel BOE HT215F01-100 1 [DS] . Various • 5991-3533EN English 2014-08-03 PDF 7 • Prology DVD-300BFM OWER MANUAL Prolodgy • GPH11DU TH-50PE8U panasonic • RXD-700 Sony •
