pawluf
Posted: Tue Jan 15, 2008 8:15 am Post subject: Samsung TV model CJ 044 |
Anyone knows this set? I need the service mode and none of the standard Samsung modes that I know works? _________________ Pawluf
Malta G.C. |
Gravityboots
Posted: Wed Jan 16, 2008 1:54 am Post subject: Samsung Service Mode Suggestion |
1. Enter the Factory Mode. Press the remote-control keys in this sequence:
PICTURE OFF(RED KEY) - DISPLAY - MENU- MUTE-PICTURE ON(RED KEY)
Use the channel and volume keys (up/down) to move the cursor. Select an alignment parameter.
Use the volume keys (up/down) to adjust the value. Adjustment must be done separately for PAL,
SECAM, NTSC color systems. (As soon as the TV receives a signal, it switches to the correct broadcast
standard.) After adjustments are completed, press the picture off key to exit the Service Mode.
Press the digit keys to directly change channel number.
VIDEO ADJUSTMENT p1
00 RED DRIVE 36
01 BLUE DRIVE 39
02 GREEN DRIVE 32
03 RED CUTOFF 31
04 BLUE CUTOFF 28
05 GREEN CUTOFF 32
06 SUB BRIGHTNESS 4
07 SUB CONTRAST 15
08 SUB COLOR 12
09 PEAK DRIVE LIMIT 63
10 YC DELAY 2 (NTSC)
8 (PAL,SECAM)
11 SUB TINT 13
12 GAMMA CORRECTION 0
DEFLECTION p1
NO CONTROL PAL NTSC SECAM
00 V-SIZE -41 -58
01 V-SHIFT 3 -10
02 V-LIN -5 -4
03 S-COLLECTION -31 -30
04 EW-WIDTH 65 59
05 EW-PARABOLA 12 14
06 H-SHIFT -2 -7
07 EW-TRAPIZIUM -9 -25
08 EW-UPPER CORNER 53 39
09 EW-LOWER CORNER 28 4
10 HOR-EHT -10 -10
11 VER-EHT -10 -10
12 BOW -1 -15
13 ANGLE -2 -3
Option p1
00 Plus (12.8 : 9) Off
01 AV Blue Screen On
02 2-Tuner PIP Off
03 LNA Off
04 ATS 1 Run On
05 Feature Box 9220
Service Mode p1
Video Adjustment
Deflection
Option
Reset |
pawluf
Posted: Fri Jan 18, 2008 7:20 am Post subject: |
Thanks _________________ Pawluf
Malta G.C. |
www.lipetsk.name
boom.bg : аукцион -
MondeTech
SEO -
Онлайн поща -
