Gravityboots
Posted: Sat Jan 26, 2008 5:19 pm Post subject: Service Modes |
Manufacturer Model Chassis Product Mode Enter
Akai CT-2119 CTV Test Mode
Simultaneous press + & - on local panel and
then power on with main switch. Exit: POWER.
Allstar 3750 CTV Hotel Mode
OFF: Select programm 38. Simultaneous press
(3 sec) STORE & CONTROL+ on local keyboard.
ON: Select programm 38. Simultaneous press
(3 sec) STORE & PROGRAM- on local
keyboard.
AudioTon CTV 5502 10.3 90° MONO CTV
Child Lock
Clear
Press UP & DOWN buttons together on tv's
local control and then switch on. You will see
SERVICE MODE. Do not press any button,
just power off the set, then on.
AudioTon CTV 5502 10.3 90° MONO CTV Service Mode
Beko CTV Service Mode
Simultaneous press P+ & P- on local panel and
Blaupunkt MM63-13VT FM240.00 CTV ATS
Press button P/C on RC and switch on TV with
main switch.
Hotel Mode
Cancel
Press button 'i' on RC and switch on TV with
main switch.
Brandt ICC9 CTV Service Mode
Switch off TV with RC (st-by). Switch off TV with
main switch. Wait a few sec till ST_BY LED
switch off. Simultaneous press VT button on RC
and switch on TV with main switch. Press VT
button again. (WARNING: scart must be free.)
Continental CT1412B CTV Service Mode
Press and hold P+ and P- on local panel, then
Ferguson ICC9 CTV Service Mode
Ferguson TX92 CTV
Hotel Mode
Cancel
Put TV into standby, then turn power off, then
turn power on whilst holding standby button on
remote and step through menus to `vol set` and
increase level to max.
Finlux
17/21B60
63/71Y2
STEREO PLUS CTV Service Mode
MUTE --> OK (M) --> TV
Controls: cursor buttons. Store: OK (M).
Exit: TV
GoldStar MC-51B CTV Service Mode
Simultaneously press MENU, VOL-, PR- on
the local panel.
Graetz
BURGGRAF
STEREO 4876
Digivision
DIGI III 110° CTV Service Mode
Turn on 'TV Internal Service Program' switch on
the digital modul (SE on display). On RC: 1=U1
V SHIFT, 2=U2 V LIN DN, 3=U3 V LIN, 4=H1
H SHIFT, 5=H2 H AMP, 6=H3 EW AMP, 7=
C, 8=C1, 9=C2, 0=H4 EW TRAPEZ…
TV=MEMO, VOL+/-=ADJUST.
Grundig CUC1800 CTV
Child Lock
Cancel
Press VOL+, VOL-, PR-, PR+, OK.
ServiceMode 3.71 by stef_no1 e-mail: [email protected]
This is ServiceModeWare. If you find this usefull send me 2 new service modes.
Grundig CUC1800 CTV
EPROM
Version Nr.
Press button 'i' to call up the 'Dialog Center' -->
OK. The version number is shown by pressing
the 'AUX' button. The index 01 of the part nr.
(19798-300.01) indicates the EPROM version.
Grundig CUC1800 CTV Service Mode
Menu guide: 'i', 'Special functions', 'Service',
'Code 8500'.
Grundig CUC1805 CTV ATS Reset
Press and hold button VOL+ on the TV and
switch the mains button ON. ATS bit is set.
Grundig CUC1805 CTV
Child Lock
Cancel
Grundig CUC1805 CTV
Default
Values
Entering
Depress and hold the button 'P-' on the RC while
switching on with the mains button. (This is
only possible once on replacement of the NVM
or uP).
Grundig CUC1805 CTV
EPROM
Version Nr.
Grundig CUC1805 CTV Service Mode
Press 'i'. Dialog Center --> Service --> 'for
authorized dealer' --> Code Number 8500.
Grundig CUC1805 CTV
Volume
Offset
Cancel
Press and hold the 'AUX' button on the RC while
switching the TV on with the mains button.
Grundig CUC1806 CTV
Child Lock
Cancel
General reset with number 7038.
Grundig CUC1806 CTV Demo Mode
Demo on: Depress and hold button 'L+' on the
TV and switch the TV on with the mains button.
Press the 'P+' button within a time of 10s.
Demo off: ATS Reset (by depressing the 'L+'
button on the TV while switching on with the
mains button).
Grundig CUC1806 CTV
EPROM
Version Nr.
Grundig CUC1806 CTV
Factory
Default
Values
Resetting
Buttons 'AUX', 'OK'.
Grundig CUC1806 CTV Service Mode
Menu guide: 'i', 'Dialog Center', 'Service', 'Only
for retailer', 'Code 8500'.
Grundig CUC1821 CTV
Child Lock
Cancel
Grundig CUC1821 CTV
EPROM
Version Nr.
Grundig CUC1821 CTV Service Mode
'Code 8500'.
Grundig CUC1822 CTV
Child Lock
Cancel
Grundig CUC1822 CTV
EPROM
Version Nr.
Grundig CUC1822 CTV Service Mode
'Code 8500'.
Grundig CUC1824 CTV
Child Lock
Cancel
Grundig CUC1824 CTV
EPROM
Version Nr.
Grundig CUC1824 CTV Service Mode
'Code 8500'.
Grundig CUC1825 CTV ATS Reset
Grundig CUC1825 CTV
Child Lock
Cancel
Grundig CUC1825 CTV
EPROM
Version Nr.
Grundig CUC1825 CTV
ROM Data
Loading
Press and hold the P- buton on the TV and
switch on with the mains button. Loading
the Average Values / Emergency Data Set
(ROM Dana). This is only possible once on
replacement of the NVM or uP.
Grundig CUC1825 CTV Service Mode
Grundig CUC1825 CTV
Volume
Offset
Cancel
Grundig CUC1826 CTV ATS Reset
Grundig CUC1826 CTV
Child Lock
Cancel
Grundig CUC1826 CTV
EPROM
Version Nr.
Grundig CUC1826 CTV
ROM Data
Loading
Grundig CUC1826 CTV Service Mode
Grundig CUC1826 CTV
Volume
Offset
Cancel
Grundig CUC1827 CTV
Child Lock
Cancel
Grundig CUC1827 CTV
Default
Values
Entering
or uP).
Grundig CUC1827 CTV
EPROM
Version Nr.
Grundig CUC1827 CTV Service Mode
Grundig CUC1827 CTV
Volume
Offset
Cancel
Grundig CUC1828 CTV
Child Lock
Cancel
Grundig CUC1828 CTV Demo Mode
mains button).
Grundig CUC1828 CTV
EPROM
Version Nr.
Grundig CUC1828 CTV
Factory
Default
Values
Resetting
Grundig CUC1828 CTV Service Mode
Grundig CUC1829 CTV
Child Lock
Cancel
Grundig CUC1829 CTV Demo Mode
mains button).
Grundig CUC1829 CTV
EPROM
Version Nr.
Grundig CUC1829 CTV
Factory
Default
Values
Resetting
Grundig CUC1829 CTV Service Mode
Grundig CUC1830 CTV
Child Lock
Cancel
Grundig CUC1830 CTV Demo Mode
mains button).
Grundig CUC1830 CTV
EPROM
Version Nr.
Grundig CUC1830 CTV
Factory
Default
Values
Resetting
Grundig CUC1830 CTV Service Mode
Grundig CUC1836 CTV
Child Lock
Cancel
Grundig CUC1836 CTV Demo Mode
mains button).
Grundig CUC1836 CTV
EPROM
Version Nr.
Grundig CUC1836 CTV
Factory
Default
Values
Resetting
Grundig CUC1836 CTV Service Mode
Grundig CUC1842 CTV
Child Lock
Cancel
Grundig CUC1842 CTV Demo Mode
mains button).
Grundig CUC1842 CTV
EPROM
Version Nr.
Grundig CUC1842 CTV
Factory
Default
Values
Resetting
Grundig CUC1842 CTV Service Mode
Grundig CUC1851 CTV
Child Lock
Cancel
Grundig CUC1851 CTV
EPROM
Version Nr.
Grundig CUC1851 CTV Service Mode
'Code 8500'.
Grundig CUC1852 CTV
Child Lock
Cancel
Grundig CUC1852 CTV
EPROM
Version Nr.
Grundig CUC1852 CTV Service Mode
'Code 8500'.
Grundig CUC1881 CTV
Child Lock
Cancel
Grundig CUC1881 CTV
EPROM
Version Nr.
Grundig CUC1881 CTV Service Mode
'Code 8500'.
Grundig CUC1892 CTV
Child Lock
Cancel
Grundig CUC1892 CTV
EPROM
Version Nr.
Grundig CUC1892 CTV Service Mode
'Code 8500'.
Grundig CUC1894 CTV
Child Lock
Cancel
Grundig CUC1894 CTV Demo Mode
mains button).
Grundig CUC1894 CTV
EPROM
Version Nr.
Grundig CUC1894 CTV
Factory
Default
Values
Resetting
Grundig CUC1894 CTV Service Mode
Grundig CUC1929 CTV
Child Lock
Cancel
Grundig CUC1929 CTV Demo Mode
mains button).
Grundig CUC1929 CTV
EPROM
Version Nr.
Grundig CUC1929 CTV
Factory
Default
Values
Resetting
Grundig CUC1929 CTV Service Mode
Grundig CUC1952 CTV
Child Lock
Cancel
Grundig CUC1952 CTV Demo Mode
mains button).
Grundig CUC1952 CTV
EPROM
Version Nr.
Grundig CUC1952 CTV
Factory
Default
Values
Resetting
Grundig CUC1952 CTV Service Mode
Grundig CUC1962 CTV
Child Lock
Cancel
Grundig CUC1962 CTV Demo Mode
mains button).
Grundig CUC1962 CTV
EPROM
Version Nr.
Grundig CUC1962 CTV
Factory
Default
Values
Resetting
Grundig CUC1962 CTV Service Mode
Grundig CUC1983 CTV
Child Lock
Cancel
Grundig CUC1983 CTV Demo Mode
mains button).
Grundig CUC1983 CTV
EPROM
Version Nr.
Grundig CUC1983 CTV
Factory
Default
Values
Resetting
Grundig CUC1983 CTV Service Mode
Grundig CUC1984 CTV
Child Lock
Cancel
Grundig CUC1984 CTV Demo Mode
mains button).
Grundig CUC1984 CTV
EPROM
Version Nr.
Grundig CUC1984 CTV
Factory
Default
Values
Resetting
Grundig CUC1984 CTV Service Mode
Grundig CUC2020 CTV
Band Limits
Cancelling
Depress and hold button 'i' on the RC while
switching on with the mains button. Move the
bar to 'AGC' in the Service Menu and operate
the buttons 'AUX', 'OK' in this order.
Grundig CUC2020 CTV
Child Lock
Cancel
Grundig CUC2020 CTV
Default
Values
Entering
(Additionally on replacement of the memory, the
Hotel Mode and the band limits are to be
deactivated and the AGC and AFC are to be
readjusted).
Grundig CUC2020 CTV Hotel Mode
switching on with the mains button. In the menu
line 'HOTEL' select 'ON' and leave the menu with
button 'i'. Cancelling the Hotel Mode: Repeat
the steps above but change 'HOTEL' to 'OFF'.
Grundig CUC2020 CTV
OSD
position
Depress and hold the 'i' button on the RC while
switching on with the mains button. Set the
OSD position in the menu and store with 'OK'.
Grundig CUC2020 CTV Service Mode
Grundig CUC2030 CTV
Band Limits
Cancelling
Grundig CUC2030 CTV
Child Lock
Cancel
Grundig CUC2030 CTV
Default
Values
Entering
readjusted).
Grundig CUC2030 CTV Hotel Mode
Grundig CUC2030 CTV
OSD
position
Grundig CUC2030 CTV Service Mode
Grundig CUC2031 CTV
Band Limits
Cancelling
Grundig CUC2031 CTV
Child Lock
Cancel
Grundig CUC2031 CTV
Default
Values
Entering
readjusted).
Grundig CUC2031 CTV Hotel Mode
Grundig CUC2031 CTV
OSD
position
Grundig CUC2031 CTV Service Mode
Grundig CUC2050 CTV
Band Limits
Cancelling
Grundig CUC2050 CTV
Child Lock
Cancel
Grundig CUC2050 CTV
Default
Values
Entering
readjusted).
Grundig CUC2050 CTV Hotel Mode
Grundig CUC2050 CTV
OSD
position
Grundig CUC2050 CTV Service Mode
Grundig CUC2051 CTV
Band Limits
Cancelling
Grundig CUC2051 CTV
Child Lock
Cancel
Grundig CUC2051 CTV
Default
Values
Entering
readjusted).
Grundig CUC2051 CTV Hotel Mode
Grundig CUC2051 CTV
OSD
position
Grundig CUC2051 CTV Service Mode
Grundig CUC6300 CTV
Child Lock
Cancel
Grundig CUC6300 CTV
Default
Values
Entering
switching on with the mains button. Menu guide:
'Horizontal Position', 'OK', 'OK', press 'i' to leave
the menu.
Grundig CUC6300 CTV Hotel Mode
Grundig CUC6300 CTV
OSD
position
Grundig CUC6301 CTV
Child Lock
Cancel
Grundig CUC6301 CTV
Default
Values
Entering
the menu.
Grundig CUC6301 CTV Hotel Mode
Grundig CUC6301 CTV
OSD
position
Grundig CUC6310 CTV
Child Lock
Cancel
Grundig CUC6310 CTV
Default
Values
Entering
the menu.
Grundig CUC6310 CTV Hotel Mode
Grundig CUC6310 CTV
OSD
position
Grundig CUC6330 CTV Hotel Mode
Grundig CUC6331 CTV Hotel Mode
Grundig CUC6360 CTV
Child Lock
Cancel
Grundig CUC6360 CTV
Default
Values
Entering
or uP).
Grundig CUC6360 CTV
EPROM
Version Nr.
Grundig CUC6360 CTV Hotel Mode
Depress and hold button 'P/C' on the RC while
Grundig CUC6360 CTV Service Mode
Depress and hold the 'P/C' button on the RC
while switching on with the mains button.
Grundig CUC6360 CTV
Volume
Offset
Cancel
Grundig CUC6365 CTV
Child Lock
Cancel
Grundig CUC6365 CTV
Default
Values
Entering
or uP).
Grundig CUC6365 CTV
EPROM
Version Nr.
Grundig CUC6365 CTV Hotel Mode
Grundig CUC6365 CTV Service Mode
Grundig CUC6365 CTV
Volume
Offset
Cancel
Grundig CUC6380 CTV
Child Lock
Cancel
Grundig CUC6380 CTV
Default
Values
Entering
or uP).
Grundig CUC6380 CTV
EPROM
Version Nr.
Grundig CUC6380 CTV Hotel Mode
Grundig CUC6380 CTV Service Mode
Grundig CUC6380 CTV
Volume
Offset
Cancel
Grundig CUC6450 CTV
Child Lock
Cancel
Grundig CUC6450 CTV
Default
Values
Entering
or uP).
Grundig CUC6450 CTV
EPROM
Version Nr.
Grundig CUC6450 CTV Hotel Mode
Grundig CUC6450 CTV Service Mode
Grundig CUC6450 CTV
Volume
Offset
Cancel
Grundig CUC6460 CTV
Child Lock
Cancel
Grundig CUC6460 CTV
Default
Values
Entering
or uP).
Grundig CUC6460 CTV
EPROM
Version Nr.
Grundig CUC6460 CTV Hotel Mode
Grundig CUC6460 CTV Service Mode
Grundig CUC6460 CTV
Volume
Offset
Cancel
Grundig CUC6469 CTV
Child Lock
Cancel
Grundig CUC6469 CTV
Default
Values
Entering
or uP).
Grundig CUC6469 CTV
EPROM
Version Nr.
Grundig CUC6469 CTV Hotel Mode
Grundig CUC6469 CTV Service Mode
Grundig CUC6469 CTV
Volume
Offset
Cancel
Grundig CUC7300 CTV
Default
Values
Entering
Depress and hold down button 'P-' on the RC
and switch the TV on from Standby with the
local 'P+' button. (This is only possible once on
replacement of the NVM or uP).
Grundig CUC7300 CTV
EPROM
Version Nr.
Grundig CUC7300 CTV Hotel Mode
Depress and hold button 'P/C' while switching
on from Standby with button 'P+' on the TV. Set
the Hotel Mode to 'OFF' with 'OK'.
Grundig CUC7300 CTV
Volume
Offset
Cancel
Depress and hold the 'AUX' button on the RC
while switching the TV on from Standby with
the local 'P+' button.
Grundig CUC7301 CTV Hotel Mode
Grundig CUC7302 CTV
Default
Values
Entering
Grundig CUC7302 CTV
EPROM
Version Nr.
Grundig CUC7302 CTV Hotel Mode
Grundig CUC7302 CTV
Volume
Offset
Cancel
Grundig CUC7303 CTV
Band Limits
Cancelling
Grundig CUC7303 CTV Hotel Mode
Grundig CUC7303 CTV
OSD
position
Grundig CUC7305 CTV
Band Limits
Cancelling
Grundig CUC7305 CTV Hotel Mode
Grundig CUC7305 CTV
OSD
position
Grundig CUC7350 CTV Hotel Mode
Grundig CUC7851 CTV
Child Lock
Cancel
Grundig CUC7851 CTV
EPROM
Version Nr.
Grundig CUC7880 CTV
Child Lock
Cancel
Grundig CUC7880 CTV
EPROM
Version Nr.
Grundig CUC7890 CTV
Child Lock
Cancel
Grundig CUC7890 CTV
EPROM
Version Nr.
Grundig CUC7951 CTV
Child Lock
Cancel
Grundig CUC7951 CTV
EPROM
Version Nr.
Grundig GV200 to GV250 VCR
Electronic
Lock Cancel
Press the 'CODE' button on the remote control
handset. Enter the numers 4 9 3 4 on the
remote control handset in this order and confirm
with the 'OK' button. Press the STOP button.
Grundig GV201-1 VCR
Electronic
Lock Cancel
Press the 'STANDBY' button on the remote
control handset until 'FREE' is indicated on the
display of the video recorder.
Grundig
GV25SV/5
GV45SV/5
VCR
Electronic
Lock Cancel
Press the 'STAND-BY' button on the RC until
'FREE' appears on the display of the recorder.
Grundig
GV280PC
GV280S
VCR
Electronic
Lock Cancel
Enter the numbers 4 9 3 4 on the remote control
handset in this order and confirm with the
button 'OK'. Press the STOP button.
Grundig
GV400
GV400GB
GV400OST
VCR
Electronic
Lock Cancel
With the video recorder switched off (Stand-by)
press the Stop button on the RC until 'UNLO'
Grundig
GV4000VPS
GV4001
VCR
Electronic
Lock Cancel
Grundig GV4003VPS VCR
Electronic
Lock Cancel
press the Stop button on the RC until 'FREE'
Grundig
GV400VPS
GV401VPT
VCR
Electronic
Lock Cancel
with the 'OK' button. Press the 'STAND-BY'
button or disconnect the recorder from the
mains.
Grundig
GV4010SV-VPT
GV4092..
GV4192VPS
GV4200SV-VPT
GV4400HiFi
GV4592..
VCR
Electronic
Lock Cancel
mains.
Grundig GV402 VCR
Electronic
Lock Cancel
Grundig
GV404SV
GV405EURO
GV406EURO
VCR
Electronic
Lock Cancel
mains.
Grundig GV410 VCR
Electronic
Lock Cancel
Grundig
GV410VPS
GV411
VCR
Electronic
Lock Cancel
mains.
Grundig GV411-1 VCR
Electronic
Lock Cancel
Press and hold the 'STAND-BY' button on the
RC (ca. 5s), until 'UNLOCKED' appears on the
Grundig
GV411OST
GV412
VCR
Electronic
Lock Cancel
Grundig
GV414SV
GV415EURO
GV416EURO
GV420VPT
VCR
Electronic
Lock Cancel
mains.
Grundig
GV430
GV430GB
VCR
Electronic
Lock Cancel
Grundig
GV430VPS
GV434SV
GV435EURO
VCR
Electronic
Lock Cancel
mains.
Grundig
GV440..
GV450..
GV460..
GV464..
GV465EURO
GV470..
VCR
Electronic
Lock Cancel
mains.
Grundig
GV500..
GV501VPT
GV505EURO
GV506EURO
VCR
Electronic
Lock Cancel
mains.
Grundig
GV5000
GV5000GB
GV5000VPS
GV5000VPS/5
VCR
Electronic
Lock Cancel
Grundig
GV5002VPS
GV5003
GV5008
GV5050
VCR
Electronic
Lock Cancel
Grundig
GV5050SV
GV5050SV/1
GV5055EURO
GV5095..
VCR
Electronic
Lock Cancel
mains.
Grundig
GV510SV
GV511
GV515EURO
GV530..
GV535EURO
GV540..
GV545EURO
GV560..
GV565EURO
VCR
Electronic
Lock Cancel
mains.
Grundig GV5300.. VCR
Electronic
Lock Cancel
Grundig
GV5395..
GV5400..
GV5695HiFi
VCR
Electronic
Lock Cancel
mains.
Grundig
GV600
GV630
GV640HiFi
GV640NIC
GV645EURO
GV650HiFi
GV660HiFi
GV660NIC
GV665EURO
GV670SHiFi
GV670SNIC
GV690SHiFi
GV690SNIC
VCR
Electronic
Lock Cancel
mains.
Grundig
GV6096SV
GV6096SV/1
GV6396SV
GV6596HiFi
GV6596NIC
VCR
Electronic
Lock Cancel
mains.
Grundig
GV740..
GV745EURO
VCR
Electronic
Lock Cancel
mains.
Grundig GV7400.. VCR
Electronic
Lock Cancel
Press and hold down the buttons 'STAND-BY'
and 'SELECT' simultaneously on the RC until
key simbol disappears from the display of the
recorder.
Grundig GV7497NIC VCR
Electronic
Lock Cancel
mains.
Grundig
GV8..
KV8..
SE8..
VCR
Electronic
Lock Cancel
recorder.
Grundig GVP600ICNEURO VCR
Electronic
Lock Cancel
Grundig
KV5001VPS/5
KV5301VPS/5
VCR
Electronic
Lock Cancel
Grundig
MV4005
MV4105
VCR
Electronic
Lock Cancel
Grundig
SE4100VPS
SE4104SV
SE4120SV
VCR
Electronic
Lock Cancel
mains.
Grundig
SE5102SV
SE5104SV
SE5106HiFi
VCR
Electronic
Lock Cancel
mains.
Grundig
SE6102SV
SE6104SV
SE6106HiFi
VCR
Electronic
Lock Cancel
mains.
Grundig SE7104SV VCR
Electronic
Lock Cancel
mains.
Grundig SE7105 VCR
Electronic
Lock Cancel
recorder.
Grundig SE7106HiFi VCR
Electronic
Lock Cancel
mains.
Grundig TVR3700 VCR
Electronic
Lock Cancel
Press and hold STOP button on the RC and
depress the PLAY button on the video recorder.
Press the 'STAND-BY' button or disconnect the
video recorder from the mains.
Grundig
TVR3701
TVR3705
TVR3710
TVR3720
TVR3730
VCR
Electronic
Lock Cancel
Press the cursor buttons on the RC in this
order: VOL+, VOL-, PR+, PR-.
Grundig
TVR4500
TVR4510
VCR
Electronic
Lock Cancel
Interconnect the service test points on the
keyboard control unit for a short period.
Switch the unit off and disconnect it from
mains.
Grundig
TVR5100
TVR5130
TVR5500
VCR
Electronic
Lock Cancel
Grundig TVR5510 VCR
Electronic
Lock Cancel
mains.
Grundig TVR5530 VCR
Electronic
Lock Cancel
Grundig VS200 to VS267 VCR
Electronic
Lock Cancel
Switch the video recorder off. Remove the top of
the cabinet. Unplug the B1 connector on the
sequence control. Switch the recorder on. After
approx. 2 seconds, re-insert the B1 connector.
Switch the video recorder off. Re-fit the top of
the cabinet.
Grundig VS300 to VS460 VCR
Electronic
Lock Cancel
the cabinet. Switch the recorder on.
keyboard control unit for a short period. Press
the STOP button. Switch the video recorder
off. Re-fit the top of cabinet.
Grundig VS500 VCR
Electronic
Lock Cancel
button '0000'. Press the STOP button.
Grundig VS505 to VS510 VCR
Electronic
Lock Cancel
Grundig VS520 to VS550 VCR
Electronic
Lock Cancel
Grundig VS600 to VS960 VCR
Electronic
Lock Cancel
ITT STEREO PLUS CTV Service Mode
Exit: TV
LG MC64 CTV Service Mode Simultaneous press OK on RC & local panel.
LG MC84 CTV Service Mode Simultaneous press OK on RC & local panel.
Loewe.
Art.-Nr. 64420
66426 66449
66450 66460
66480 66490
C9000 CTV
TV Service
Mode
Simultaneous press CM on the RC & "Service"
key on the control panel. Select: MEM IN/OUT.
Adjust: VOL +/-. Store: X. Exit: TV.
Loewe.
Art.-Nr. 64420
66426 66449
66450 66460
66480 66490
C9000 CTV
VT Service
Mode
Simultaneous press VT on the RC & "Service"
Loewe. C9003 CTV Service Mode
On the local control press function key five times
(indication "Service" will appear), afterwards
within a sec. press key "MEN" on the remote
control. Store: X. Exit: TV.
Loewe. Q2200 CTV Service Mode
Go to 'SERVICE' in menu and then quick press
'MENU' on the RC. Select: yellow cursors.
Adjust: +/-. Store: 'X'. Exit: 'TV'.
Luxor
5585-21A1
7057-27
63/7954
Exit: TV
Mitsubishi CT21M5E CTV Service Mode
Press S701 (on board) and button 9 (in 5s).
Store: '0'. Exit: stand-by.
NEC
XExx
XPxx
XVxx
MON Service Mode
Select DISPLAY MODE. Press PROCEED.
Press and hold RESET. Then simultaneous
press + & -. 'Warning Entering Service Menu…'
appears. Press PROCEED for enter. Be
careful! You can damage a monitor!
Nokia 6364, 7364 2B-F CTV Service Mode Quick press: --\-, MENU, TV.
Nokia EUROSTEREO CTV Service Mode
In 1s press buttons '-/--', 'MENU', 'TV'. Select:
PR+/-. Adjust: VOL+/-. Store: fill-dot-symbol
on RC (near 'i' button). Exit: 'STANDBY'.
Nokia
63/7168 55A1-0
45H1-0 55Y2-0
63/7157 63/7177
Exit: TV
Nokia STEREO PLUS CTV Service Mode
i --> M --> PROGR.
Controls: cursor buttons. Store: M.
Exit: TV
Nordmende DC1 CTV Service Mode
Switch to Standby. Switch off with the mains
switch. Press and hold red button on RC and
then switch on with the mains switch (cca 10s).
Select: numbers buttons. Adjust: +/-. Store:
red button. Exit: 'MUTE'.
Nordmende DC2 CTV Service Mode
Nordmende Color 3038 F15-03 110° CTV
MDA2061
Replacement
After replacement of the MDA2061 (IR73) the
TV receiver acts as folows: a) All programme
storages have stored Ch00. b) The indicator
shows German function characters. c) PAL and
SECAM EAST standard recepcion is possible
(not NTSC and/or SECAM WEST).
If required to change according to paragr. b and
c then switch off the set by the mains switch.
Press both buttons + and - for volume on TV
and simultaneously switch the set on with the
mains switch. Keep the two volume buttons
pressed until the display indicates Pr. After 8s
the display indicates __. Now the following
buttons can be presseed on the RC, thus
additional corresponding segments will be
illuminated: Button '1' function symbols indicate
international display. Reversible to German
display with button '2'. Button '5' additional
SECAM WEST and/or NTSC reception
(Multistandard). Reversible to Single Standard
with button '3'. Store: Stand-By.
Nordmende ICC10 CTV Service Mode
Switch to Stand By. Switch off with the mains
switch. Press and hold 'VT' on RC then switch
on with the mains switch.
Nordmende ICC9 CTV Service Mode
switch off. Simultaneous press blue button on
RC and switch on TV with main switch. Press
blue button again. (WARNING: scart must be
free.)
Palladium TV-100 CTV Service Mode
Simultaneous press red & blue buttons on RC
then (in 5 sec.) simultaneously press P- & P+
on local keyboard. Commands: arrows. Store:
OK. Exit: TV.
Panasonic EURO-1 CTV Service Mode
In Sound-Menu Low-tone-regel to MAX and
High-tone-regel to MIN. Press VOL- on TV
and RESET on RC in some time. Select: red
and green buttons. Adjust: yellow and blue
buttons. Store: 'STORE'. Exit: switch off.
Panasonic EURO-2 CTV Service Mode
High-tone-regel to MIN. Press 'F' button on TV.
Then press VOL- on TV and REVEAL on RC in
some time. Select: red and green buttons.
Adjust: yellow and blue buttons. Store:
'STR'. Exit: 'N' on RC.
Panasonic
MX-3
MX-3C
CTV Hotel Mode
ON: Press simultaneously 'OFF TIMER' on RC
and 'CH.UP' local.
OFF: Press simultaneously 'OFF TIMER' on RC
and 'VOL-' local.
Panasonic
MX-3
MX-3C
CTV Service Mode
Simultaneously press 'RECALL' on RC and
'VOL-' local. Exit: 'NORMAL' on RC.
Philips ANUBIS B CTV Hotel Mode
ON: Set HOTEL ON in Service Menu. Select
programm 38. Simultaneous press (3 sec)
INSTALL & P- on local keyboard.
OFF: Set HOTEL OFF in Service Menu.
Philips ANUBIS B CTV Service Mode
Simultaneously press VOL+ & P- on RC.
Exit: STANDBY.
Philips Anubis S CTV Hotel Mode
(3 sec) PR+ & VOL- on local keyboard.
(3 sec) STORE & PR- on local keyboard.
Philips L7.1A CTV Service Mode
With special service RC. Or short M25, M25
on board and then switch on TV. Exit: st-by.
Philips L9.1 CTV Hotel Mode
Select program 38 on the TV. Simultaneously
press the keys VOLUME- and VOLUME+ on
the keyboard of the TV and the OSD key of
the remote control.
Philips L9H CTV Service Mode
This model also supports the 062596 sequence
followed by [MENU] (service default) or
[i+]/[OSD] (service mode).
Philips MD1.2E CTV Service Mode
There is a small Service jumper to short on the
small signal PCB. When the TV is in this first
level service mode, you can go in the second
level service mode by pressing both MENU
and - keys on top of the TV at the same time.
There you can read much parameters and
proceed with most of the adjustments. In fact
this method let you use an ordinary Remote
control but you also need to open the back
cover. With the special service remote control,
a special code is sent to enter the service mode.
Philips MG3.1E CTV Service Mode
Option 1: In the TV-set itself is a 3-pin connector
with which either SERVICE-DEFAULT or
SERVICE-MODE can be activated. This
connector is depicted 0356 (SERVICE-PINS)
on page K7 (TXT&CONTROL). Shorting pins 1-2
will activate SERVICE-MODE. Shorting pins 2-3
will activate SERVICE-DEFAULT. Option 2:
Activate these modes using the remote control.
Obviously option 2 is the preferred method
because the settings have to be changed using
a remote control anyway.... To activate
SERVICE-DEFAULT: Press 0 6 2 5 9 6 and then
the [menu] button. The message ‘Service Default’
appears and channel ‘SER T’ will be selected.
This only sets some settings to a preset value
(color/brightness/volume and such). This mode
is primarily intended to be used when the non
volatile memory has been replaced. It is then
loaded with the default values. To activate
SERVICE-MODE: Press 0 6 2 5 9 6 and then
the [i+] button. After pressing 0 6 2 5 9 6 the
message ‘Dealer’ should have appeared.
Do not worry about the channel changing while
you press the numbers.
Service technicians have the means service mode using a special remote Philips 29PT9416 MG7.1 CTV Service Mode
Use the standard remote control an key in a
special sequence 0 6 2 5 9 6 followed by
pressing the 'MENU' button. If the main menu
also appears with the service menu just press
'MENU' again to clear it. The other way is to
short the two service pins on the signal panel
(pins 2 and 3 of connector 0356). The advantage
of this last method is that all the software
protections are turned off.
Philips Y6 CTV Service Mode
Philips VR210/58 VCR
Modulator
off
Without cassette. Press and hold SYSTEM till
'G591' appears. Press and hold CLEAR(CL) till
'MOFF' appears. Exit: TV/STANBY.
Modulator
on
'MOFF' appears. Press and hold CLEAR(CL) till
'G591' appears. Exit: TV/STANBY.
Philips VR220/58 VCR
Child Lock
Cancel
Press CHILD LOCK (key-simbol) on the RC
for 5s with the VCR switched on.
Modulator
on/off
Without cassette. Press and hold STOP on the
RC and then press STOP/EJECT on VCR.
Select the line 'MODULATOR' on the TV screen
or 'MOD+' in the display with P+/-. In the display
select 'OFF' / 'MOD-' (modulator off) with VOLor
'MOD+' (modulator on). Confirm with OK.
Exit with MENU
Modulator
preset
Without cassette. Hold the STOP button on the
RC. In addition press the STOP/EJECT button
on the VCR until the pre-set modulator
frequency appears in the display, e.g. 'M591'
(591MHz or 36 ch. UHF). Select line 'OPTIMIZE
FREQUENCY' using P+/-. Enter new
modulator frequency with the numbers 0-9. In
line 'SOUND SYSTEM' select the TV system
using VOL+/-. 'G' = PAL B/G. 'K' = SECAM D/K.
Confirm with OK. 'STORED' will appear briefly
on the screen.
Reset to
factory
settings
Disconect from the mains power supply. Press
and hold the STANDBY/ON button on the device
and reconnect to the mains power supply.
Release the button when 'OSD' appears in the
VCR display.
Philips VR400/58 VCR
Auto ST-BY
off
Press and hold STOP till [] appears.
Modulator
off
Modulator
on
Modulator
preset
Without cassette. VCR st-by. Press and hold
SYSTEM till 'G591' appears. System change:
SELECT. Freq. Change: P +/-. Store: OK.
Exit: TV/STANBY.
Revox D-TV C9003 CTV Service Mode
Saba
ULTRACOLOR
T55U42 T55U43
T63U42 T63U43
ICC5115ML 110
ICC5116MM 90°
CTV
Combination
Lock Cancel
Switch off set with main switch. Switch on set
with main switch and during doing this press
the buttons + and - of volume control on the
set's control bord simultaneously until the
display lights. Display: SS… Press the button
'S' on the RC. Switch off with RC. Now the
combination lock is unlocked and one can
switch on again in the normal manner.
Saba ICC9 CTV Service Mode
Saba T7032VT TX92 CTV
Hotel Mode
Cancel
Salora 28N8S 2B-F CTV Service Mode Quick press: --\-, MENU, TV.
Salora
17/21SF 25/28X71
25/28SP50
Exit: TV
Samsung
CB-14F1 CB-20P30
CB-20H1 CB-20S20
CB-21H1 CB-21P30
CB-21S20 CB-3373
CB-5020 CB-5073
CB-5079 CB-5320
CB-5373 CB-5379
S15A CTV Service Mode
STAND-BY --> DISPLAY --> P.STD -->
MUTE --> POWER ON.
Controls: VOL +/-, CH +/-. Exit: POWER OFF.
Samsung CK5038 SCT11B CTV Service Mode
STAND-BY --> P.STD --> HELP --> SLEEP -->
POWER ON.
Controls: VOL +/-, CH +/-. Exit: STATUS.
Samsung CX5944 CX6844 SCT12B CTV Service Mode
POWER ON.
FACTORY MODE: set PSL=15 and PVA=63.
Samsung
CB-14V10 CB-3373
CB-14V20 CB-5073
CB-20P30 CB-5079
CB-20S10 CB-5373
CB-20S20
CB-21P30
CB-21S10
CB-21S20
SCT13B CTV Service Mode
POWER ON.
Samsung CS7272 SCT51A CTV Service Mode
PICTURE OFF --> SLEEP --> P.STD -->
MUTE --> PICTURE ON
Samsung
CS-721
CS-723
SCT52A CTV Service Mode
MUTE --> PICTURE ON
Samsung
TVP3350
TVP5050
SCV11A
SCV11B
CTV/VCR Service Mode
STAND-BY --> P.STD --> MENU -->
SLEEP --> POWER ON
Schneider DTV 1 CTV Service Mode
Simultaneous press Service-button on digibord
& button C on RC. Selection: Bass +/-.
Adjust: Volume +/-. Store: T. Exit: TV.
Schneider DTV 100 CTV Service Mode
then (in 5 sec.) simultaneous press P- & P+
OK. Exit: TV.
Schneider DTV 2 CTV Service Mode
Like DTV 1 or simultaneous press Servicebutton
(down right on RC) & C button on RC.
Selection: Bass +/-. Adjust: Volume +/-. Store:
IDEAL. Exit: TV.
Schneider DTV 3 CTV Service Mode
VOL+ on local keyboard. S |
Gravityboots
Posted: Sat Jan 26, 2008 6:49 pm Post subject: Yes |
To answer many question at once. |
Poblizo.com : ïúòåøåñòâèÿ
TA8637BP Toshiba • MZ-NE410 Sony • 31GT720 RCA • Allocchio Bacchini 521 531 534 ALLOCCHIO • 832B EMERSON • smg2301p Secos • bf996s 1 Philips • CCE+DVD-2940D CCE • 09 PCB Diagram Samsung • 2sc5993 Inchange Semiconductor •
