wrazoru Guest
Posted: Tue Feb 19, 2008 7:08 am Post subject: Fuses in electrical cable for laptop |
I have a power cord plug to my laptop with a Malaysian style plug. This plug has a 3Amp fuse built in to it. I have an identical plug that I would like to use too so that i can leave it at the office. The only difference is that this other plug has a 13Amp fuse in it. (see image for both plugs)
I would assume that if i changed the fuse, they would both be identical?
Also, can i still use the 2nd plug w/ 13Amp fuse without any problems...although i'm sure if there were a surge larger than 3amps, that it wouldn't protect my device. |
Posted: Tue Feb 19, 2008 4:25 pm Post subject: |
In general, it is never a good idea to override with a higher amp fuse as it translates to little or no protection if/when there is a short on the line.
Jumping from 3A to 13A is like not having any fuse protection in this case |
Posted: Wed Feb 20, 2008 1:31 pm Post subject: |
Most likely, the laptop charger also has an internal fuse at the power input.
Mains plugs according to UK standards use to have an incorporated fuse, due to the fact that there are no group fuses in the house installations according to UK practice. The plugs are always rated at 13 A, but the rating of the installed fuse depends also on the connected equipment, cross section area of the cable and so on.
However, why not change the 13 A fuse in the other power cable to a 3 A fuse? Those fuses are always readily available in countries using UK style mains plugs. |
1MB5-Detailed Specification Aug79 HP • CR 150 Grundig • Audio 2 Braun • Cornford MK50HII CORNFORD • Инструкция DCM-290 DENON • Multichannel Measurements in MIMO 802.11 • 2sd1479 Inchange Semiconductor • 19781206 Notetaker Keyboard xerox • ksa1614 Fairchild Semiconductor • GC30-2024-3 OS MFT and OS MVT TCAM Progr •
