VCR Image Breakup: How Can I Troubleshoot/Repair?
toubleshooter
PostPosted: Mon Mar 03, 2008 6:52 am    Post subject: VCR Image Breakup: How Can I Troubleshoot/Repair? Reply with quote
. . . hi everybody; great forum here!
I'm hoping somebody can walk me though the process of fixing my VCR.
It just started to display a snowy and broken up image upon playback.
. . . thanks!
troubleshooter Wink [/b]
PostPosted: Mon Mar 03, 2008 8:58 am    Post subject: Reply with quote
clean or replace the head drum
troubleshooter
PostPosted: Tue Mar 04, 2008 4:46 am    Post subject: Reply with quote
. . . thanks gary!
I tried using a Bib brand (U.K.) video head cleaner on said vcr prior to posting here, but to no avail.
This head cleaner cartridge has push button format for cleaning fluid application, but it is years old, so I'm wondering if perhaps the cleaning fluid reservoir is spent.
I'm going to buy a fresh cleaning cartridge, try it, and will post back with results.
hopefully it won't get to having to replace head drum . . .
. . . thanks again for responding!
troubleshooter Wink
gridnutter
PostPosted: Thu Mar 06, 2008 9:42 pm    Post subject: Reply with quote
Get the lid off the player and clean the heads / drum with an alcohol based cleaner (Isopropyl alcohol for example). Put some onto a lint free cloth, or better still invest in some head cleaning wipes and apply gently to the head / drum whilst slowly rotating the head by hand, be extremely careful not to damage the heads. Make sure you get all the oxide deposits out of the corners of the drum too, and off the capstan motor drive spindle.
If this doesn't work it's new heads needed.
troubleshooter
PostPosted: Fri Mar 07, 2008 2:46 pm    Post subject: Reply with quote
. . . thank you gridnutter!
I will try what you have suggested and post back with the results.
Just one question before I attempt this: you mentioned making sure I get all the oxide deposits out of the corners of the drum as well. The drum is of course cylindrical, so I'm not sure just what you mean by corners of the drum . . . if you (or anyone else reading this who may know) could post back clarification on just this one concern, then I should be ready to give it a go!
. . . thanks!
troubleshooter Wink
gridnutter
PostPosted: Fri Mar 07, 2008 2:54 pm    Post subject: Reply with quote
Hi
The drum has a "ridge" that guides the tape around it. The ridge tapers off and tends to be a collecting point for oxide build up which can push the tape out of alignment with the head, especially on the right hand side of the drum when looking at it from the front of the VCR.
PostPosted: Tue Mar 11, 2008 12:24 pm    Post subject: Reply with quote
. . . hi gridnutter and gary and all who may be reading,
I attempted said cleaning (with lint free cloth and isopropyl alcohol) and here's what resulted:
1) The pre-cleaning, snowy image breakup became good image upon post-cleaning playback, but only on the top two thirds of the monitor. The bottom third of the playback display continued to experience snowy image breakup.
2) Cleaning process resulted in new tape feeding problem. Upon play, tape now rides up on, over and off the guideposts (not sure what those are technically called), and tape starts to gang or scrunch into end spool on cassette.
. . . any thoughts or advice on where to proceed from here would be most appreciated.
. . . thanks all in advance!
troubleshooter Wink
troubleshooter
PostPosted: Tue Mar 11, 2008 12:31 pm    Post subject: Head Drum Cleaning Attempted . . . Reply with quote
troubleshooter Wink
PostPosted: Tue Mar 11, 2008 12:49 pm    Post subject: Reply with quote
Do you think it might be helpful if you posted the make and model of this VCR? Idea
_________________
Want To Fix Something?
http://www.manuals4you.com
http://www.justmanuals.com
troubleshooter
PostPosted: Tue Mar 11, 2008 12:57 pm    Post subject: Reply with quote
hi Justmanuals,
JVC HR-D55OU.
. . . thanks for asking!
troubleshooter Wink
