g0rak
Joined: 19 Mar 2008 Posts: 6 Location: Brighton, England
Posted: Sun Mar 30, 2008 12:58 pm Post subject: Sourcing replacement capacitors in the UK? |
Hi there,
Does anyone know a good place to source high-grade (e.g. metal foil) polypropylene capacitors in the UK?
In particular I'm looking for 1uF and 2.2uF values at 630V but most places do not stock polyporpylene's up to this value. I've heard WIMA's MKP10 or FKP1 series would be ideal but cannot find stockists for them that go up to 1uF.
I've tried Maplin, RS, Charles Hyde, an extensive Google search and phoning round many local TV repair companies all to no avail.
Any responses welcome!
Thanks, Si |
Posted: Mon Mar 31, 2008 8:05 am Post subject: |
Have you tried Farnell, www.farnellinone.com ?
Another possibility for larger polypropylene capacitors is to not look at the catalog pages for "electronics" capacitors but check out the larger types for electric power uses (PFC for fluorescent tube fittings, starting capacitors for induction motors etc). Although they don't fit in well on a PCB, they have good electrical properties. Usually, they have 6,3 mm blade connectors and a M8 bolt for fastening. |
g0rak
Posted: Fri Apr 04, 2008 9:36 pm Post subject: |
Farnell online turned out to be the supplier of choice. I wasn't quite able to find all the values I wanted (substituted a 2.2uF for 1.5uF) but the TV actually had a 1uF soldered in the 2.2uF place anyway so this should be okay. There was no separate category for "metal-foil" polyprops so I had to do a lot of data sheet checking to find suitable components. Luckily there is a data sheet associated with each product on the Farnell web site so this was made as easy as possible.
There was a minimum order of £20+VAT so I ordered some solder and other stuff + some spare caps in case anything goes wrong.
Thanks for all your help.
Simon |
www.lipetsk.name
boom.bg : аукцион -
MondeTech
SEO -
Онлайн поща -
