Sylvania 32" Degauss problem
ntfday
PostPosted: Tue Apr 15, 2008 3:29 pm    Post subject: Sylvania 32" Degauss problem Reply with quote
I have a Sylvania 32" TV that took a lightning strike. It took out half of the low voltage power supply which I fixed and it will fire up without the degauss cable plugged in, but will pop the fuse when the degauss cable is plugged in. I don't have the schematic for the set. anyone have any ideas?
Old Bassid
PostPosted: Wed Apr 16, 2008 6:57 am    Post subject: D- Gauss u/s Reply with quote
Lissen Whippersnapper- all you have to do is remove the PTC unit & r/p with good one of same characteristics. If yer dunno wot a ptc is then find your local tv repairman- REALLY!!- dese iggerant posters!!!.
PostPosted: Thu Apr 17, 2008 2:20 am    Post subject: Re: D- Gauss u/s Reply with quote
Why don't you go crawl back into your hole.
Old Bassid
PostPosted: Thu Apr 17, 2008 8:03 am    Post subject: Reply to RUDE MONGREL!. Reply with quote
WELL!!!_ Ihave never been so insulted!!!(should i get around more?). Actually the hole kicked me out(can't understand why!}
PostPosted: Thu Apr 24, 2008 3:39 pm    Post subject: Reply with quote
Anyone else with any ideas?
PostPosted: Thu Apr 24, 2008 6:21 pm    Post subject: Reply with quote
First thing, are you sure of using the correct fuse?(sloblo vs normal?I seemed to remember being a problem on some sets?)
Otherwise, sounds like either a problem with thermistor &/or varistor used to control the coil. Do not have specific diagram but if you were able to tackle the power supply issue, should not be hard to pinpoint the cause of exceess current draw by the degauser.
Can you follow & draw the path thru the coil? It is mainly the AC applied to the coil & controlled by some sort of a thermistor or timed device to effectively reduce/disconnect full AC from the coil in an instant.
How about using a variac to bring it up slowly as you monitor the current draw?
ntfday
PostPosted: Wed Apr 30, 2008 12:52 pm    Post subject: Reply with quote
vtech, thanks for your answer. I must have been having a senior moment as the problem was the fuse. A 4 amp slo-blo cured the problem.
