printed circuit tracer repair
Rwright955
PostPosted: Wed Apr 23, 2008 9:08 pm    Post subject: printed circuit tracer repair Reply with quote
Any tips for repairing a tracer on a printed circuit that has been pulled up do to removing IC chip that had one wire still partially held by solder. It pulled about a 1/4 inch from the location where the IC chip should be soldered. There is now no place to solder the one connector. I know I messed up, but can I save it? Thanks
PostPosted: Wed Apr 23, 2008 9:39 pm    Post subject: Reply with quote
If you broke a trace, follow that trace to the next component it would have ran to. Simply solder a jumper wire from the leg of the IC to where it would have went to anyway.
rwright955
PostPosted: Thu Apr 24, 2008 2:55 am    Post subject: circuit board tracer Reply with quote
What type and guage of wire should I do the repair with? Thanks again.
PostPosted: Sat Apr 26, 2008 6:39 pm    Post subject: Reply with quote
That depends on the size of the broken route on the PCB, which currents are expected there and so on.
Usually, legs from hole mounted resistors etc are a good choice, if the layout is crowded and you need a thinner wire, then use wire-wrap wire. In case of broad routes and high currents, like in power supplies or television horizontal output stages, it is common to use a broad solder wick for repairing.
