yangandjiao
Posted: Sun May 04, 2008 2:11 am Post subject: JAN1N826AUR-1TR DATA |
DESCRIPTION APPEARANCE
The 1N821UR thru 1N829AUR-1 series of surface mount Zero-TC Reference Diodes provides a selection of both 6.2 V and 6.55 V nominal voltages and temperature coefficients to as low as 0.0005%/oC for minimal voltage change with temperature when operated at 7.5 mA. These glass
surface mount DO-213AA (MELF) reference diodes are optionally available with an internal-metallurgical-bond by adding a “-1” suffix. This type of bonded Zener package construction is also available in JAN, JANTX, and JANTXV military qualifications. Microsemi also offers numerous other
Zener Reference Diode products for a variety of other voltages up to 200 V
FEATURES APPLICATIONS / BENEFITS
• Surface mount equivalent of JEDEC registered 1N821 thru 1N829 series
• Internal metallurgical bond option available by adding a “-1” suffix
• Reference voltage selection of 6.2 V & 6.55 V +/-5% with further tight tolerance options at lower voltage
• 1N821, 823, 825, 827 and 829 also have surface mount qualification to MIL-PRF-19500/159 by adding the JAN, JANTX, or JANTXV prefixes to part numbers a well as the “-1” suffix; e.g. JANTX1N829-1, etc.
• Axial-leaded equivalents also available in DO-35 or DO-7 without the UR suffix (see separate data sheet) including military qualifications up to JANS for DO-7 (see separate data sheet)
• JANS equivalent available in DO-213AA via SCD
• Provides minimal voltage changes over a broad temperature range
• For instrumentation and other circuit designs requiring a stable voltage reference
• Maximum temperature coefficient selections available from 0.01%/ºC to 0.0005%/ºC
• Tight reference voltage tolerances available with center nominal value of 6.15 V by adding designated tolerance such as 1%, 2%, 3%, etc. after the part number for identification e.g. 1N827UR-2%, 1N829AUR-1-1%, etc.
• Small surface-mount footprint
• Nonsensitive to ESD per MIL-STD-750 Method 1020
• Typical low capacitance of 100 pF or less
JAN1N826AUR-1TR PDF |
samsung ph63klflbc-xf chassis d84c Samsu • LX3700D Philips • LG 65EG9600 ub Chassis EA59E sm LG • 2sd2321 e Panasonic • T 7000 Grundig • DVD710 SB-SI 4651209001 Philips • B100 027 CANON • fdms9620s Fairchild Semiconductor • PC PC07X2 CHASSIS TV D LG • tys New 2011 possibly •
