VanNess
Posted: Fri May 09, 2008 10:24 pm Post subject: Toshiba 50h72 picture problems |
I just bought a used toshiba 50h72. The picture is "scrolling" to the side. When I first turn it on, it's real bad, but as the tv warms up, it gets a little better, but does not completely fix. What is the problem. What can I do so that I don't have to pay outrageously for it to be fixed? |
Posted: Fri May 09, 2008 11:25 pm Post subject: |
Subject: MVPU14 Hyper Module Repair (23148024 / 23148024P / 23148024X)
Symptom: Multiple Symptoms may be experienced depending on which capacitor is
faulty. The primary symptoms are jagged, digitized or pie crusting of the
picture. The set may also be described with a poor sync condition.
Corrective Action: Remove the MVUP14 Hyper Module from the TV chassis, remove
the top shield and replace the 10uf, 16v capacitors using Part Number
24619040 as shown in Figure 1. It’s recommended that all of the
capacitors identified in Figure 1 be replaced. (Note: These capacitors are
low impedance surface mounted aluminum electrolytic capacitors. Care
should be taken to avoid damaging the PCB while replacing these
capacitors.) |
Posted: Fri May 09, 2008 11:30 pm Post subject: |
Behind the audio/video jack is a metal can, it will say MVPU14 on the top. The 4 legs from the bottom need to be unsoldered and that can removed. There are 11 caps that need to be replaced or you can send it to PTS. |
hfe denon dcd-1420 service DENON • hcd-h61 h61m 104 panasonic • A28-6306-1 7090 7090 Bilbliography Apr64 • 22sj520 2 • Samsung LN46D550K1FXZA fast track guide • LX444AB Philips • Panel AUO B156HW02 V1 2 [DS] . Various • 180c 180d service 6 Agilent • 679DCbk0 Dell • c1 board panasonic •
