Pundit Moshai
Posted: Mon May 12, 2008 8:25 am Post subject: Computer power supply trouble |
My Computer ATX 400W SMPS power supply is giving low voltage output --i get +4VDC and +10VDC instead of the normal +5V and +12V DC--can anyone please give me any suggestions on how to repair?--the circuit uses SG6105 20 pin chip as PWM IC---the equivalent is the HS8108 chip---thanks! |
Posted: Mon May 12, 2008 10:41 am Post subject: |
I think you should first check for bad electrolytic caps in the power supply. Usually, but not always, the bad ones can be identified by a bulging top and possibly leakage. Small capacitors (6-7 mm diameter and smaller) that have been subjected to heat from other components often get bad without bulging.
Also, check for open diodes in the primary bridge rectifier. If one of them is open, the bridge will operate as a half-wave rectifier, causing too low voltage and much mains frequency ripple on the primary DC bus. The voltage there should normally be 1,4 x the mains voltage if the power supply has no PFC (power factor correction, mandatory in Europe since some years and becoming more and more common worldwide). For units with passive PFC (a big coil with laminated core in series with the mains input), that voltage will be somewhat lower, while units with active PFC always have a higher DC bus voltage, typically 350-380 V. |
9manuals
Joined: 04 Jun 2008 Posts: 10 Location: http://www.9manuals.com
Posted: Thu Jun 05, 2008 12:11 am Post subject: Replace it |
Nobody repairs ATX power supply, just by one for about 20$ and replace it _________________ 9manuals
Exclusively Laptop Manuals. The richest collection of all brand Laptop Service and Users Manuals on the Internet. Well organized, you find your manuals in seconds. Instant, Automatic Downloads day or night – www.9manuals.com |
Posted: Thu Jun 05, 2008 2:26 am Post subject: Re: Replace it |
9manuals wrote: | Nobody repairs ATX power supply, just by one for about 20$ and replace it |
No Ashton, people in third world countries do & have always been fixing things as much as possible---strictly out of necessity & economics. |
GVC-9002A Wards Airline • T230, T290 1 Sony Ericsson • Junior 109B ITT Schaub-Lorenz • tx p50gt30e j panasonic • PFL serie (all model) Philips • Panasonic 103 inch plasma [TM] panasonic • VPC-SX550 Sanyo • CN-NBL54LH aiwa • p25-block Philips • 938a Philips •
