jamesbell Guest
Posted: Fri May 23, 2008 8:32 pm Post subject: problem tunning philips tvwith sky box |
Can you help me on this. I have a Philips TV that can't be tuned into sky. It has autostore function and finds Sky picture on 847Mhz but no sound, even when I try fine tune I can't get sound. I have tried other televisions and they work fine. This tele works ok with other inputs. It is connected through amplifier in loft on Sky rf2 output,channel68.
cheers
James |
Posted: Fri May 23, 2008 11:13 pm Post subject: |
Just making a guess here, do you try changing from cable to antenna to see if you get sound? |
jamesbell Guest
Posted: Sat May 24, 2008 7:37 pm Post subject: |
Anonymous wrote: | Just making a guess here, do you try changing from cable to antenna to see if you get sound? |
tried it today and no sound direct to ariel either, strange as works through scart. Do you think it has someting to do with ariel input?
cheers
James |
Posted: Sat May 24, 2008 8:21 pm Post subject: |
Do you get sound when you hook it up scart? If you do you have a bad tuner I would assume. |
jamesbell Guest
Posted: Sat May 24, 2008 8:38 pm Post subject: |
minnie wrote: | Do you get sound when you hook it up scart? If you do you have a bad tuner I would assume. |
yep get sound through scart, can tuner be replaced? |
Posted: Sun May 25, 2008 5:58 pm Post subject: |
Not familiar with sky box, assuming it's a satellite box. Is it a free view box or a subscribed box? |
