holls69
Posted: Sat May 31, 2008 2:54 am Post subject: Re: mitsubishi 42 inch tv shutting off by itself. |
[quote="[email protected]"]I HAVE A MITSUBISHI 42INCH WT-42313. IT SHUTS OFF BY ITSELF. SOMETIMES CAN'T TURN IT BACK ON. RED, BLUE AND GREEN AT SIDES OUT OF FOCUS. IS IT WORTH FIXING. I GOT A CODE 24. |
Posted: Sat May 31, 2008 4:12 pm Post subject: |
Please, do not post in caps. When you say out of focus I'm assuming you mean you lost convergence correction. If your convergence is off you need to replace the 2 STK394-250's. |
joetiz Guest
Posted: Fri Aug 29, 2008 5:31 pm Post subject: Mitsubishi vs-45609 |
The problen started off with convergence problems then the TV would turn on for a second(just sound) then shut down.withe the timer light on steady.. Now the timer lght stays on and the TV does nothing when power button is pressed .I tryed unplugging and waiting 10min and plugging back in no help any suggestions. |
nja62 Guest
Posted: Wed Jan 13, 2010 3:58 am Post subject: Mitsubishi WD-62825 blinking green light |
The model I have is the WD-62825.
I had the blinking light of death and could not get the TV to respond to the remote or the front panel.
I read somewhere that if you hold down the Menu and Device button on the front of the TV, the light will blink differently than normal and the light goes off, like it's powering down.
Then I waited a few minutes then hit the power button and it powered up like normal.
It's been on for about an hour or more with no problems.
Maybe this will help you. |
DMM7510 Firmware v1.1.0f Keithley • phb9nq20t phd9nq20t php9nq20t 2 Philips • ss8550 Secos • MaxLine ІІ 250 GB maxtor • tip3055 Bourns • PT-LB10NTU ALL SVC panasonic • 04-lubrication system Honda • Adj Di181 020 Minolta • QS-6 Alesis • stv355 CHOV •
