vertical problem
thefixer
PostPosted: Sat Jun 07, 2008 8:53 pm    Post subject: vertical problem Reply with quote
hello every body ,I have Siera tv model sa2110 it has analog processor and analog processor tda9381ps/n3/2/1831.vertical chip is la78040.i checked its voltage supply it is about 16v .i substitute that chip but in vain .I think that there is no vertical signal .any one tohelp me with this .thanks in advance.
PostPosted: Sat Jun 07, 2008 9:14 pm    Post subject: Reply with quote
Have you replaced the pump up cap? Replace all the caps around the vertical IC. Depending on the age, the B+ should come off the flyback, go threw a protect resister then diode. You probably fried the IC again.
thefixer
PostPosted: Thu Jun 12, 2008 10:46 am    Post subject: vertical problem Reply with quote
[quote="minnie"]Have you replaced the pump up cap? Replace all the caps around the vertical IC. Depending on the age, the B+ should come off the flyback, go threw a protect resister then diode. You probably fried the IC again.[Yes i verified all cap around it .all components are ok.Finally i find that 7808 regulator doesn't work well .it was the cause.Thanks again for your advice Smile
