Monitor AOC LM727 goes black after about 12 seconds
PostPosted: Wed Jun 11, 2008 9:44 am    Post subject: Monitor AOC LM727 goes black after about 12 seconds Reply with quote
On my AOC LM727 the screen goes black after about 12 seconds after booting. If i turn off the screen and on again, it comes back for 12 seconds, and then goes black again. When the screen is lit it also has a lower brightness than usual.
It must be caused by some bad connector inside because if i give it a knock or a push, while there still is an image on the screen, I can make the brightness to go up to normal, and then the screen remains on for hours.
But then next time I boot up the problem is back.
I am an electronic technician, and I have tried to open the cabinet, but can't find any screws at all. Anyone knows anything on how to open it?
PostPosted: Sun Jun 22, 2008 3:01 am    Post subject: Reply with quote
I have an LM729 which is likely the same thing. There will be a plastic bezel around the stand which is gently pried off to expose 4 screws. Next You will have to open the trim around the screen and gently! pry it apart. There should be a small plastic latch every 6ish inches (15 cm.) The 8 screw holding the crt to the base will be obvious.
I have the same fault on my monitor cept its every 4 seconds it blanks. I have found 2 open transistors on the PSU which I am trying to find part numbers for. I have used this site in the past...very impressed, good luck with your unit
Radar[/quote][/code]
PostPosted: Sat Jul 19, 2008 6:04 pm    Post subject: Reply with quote
Sounds like the same problem I had with my LM727, it would display the logo then a second
of windows then go blank with the power light still green, I read some where that resoldering
the coils on the power supply circit board would fix the problem because they are known to
have dry solder points.. There is a site with a link that details the procedure google "AOC Coils" should be the first one.
HTH.
SZASZ
PostPosted: Tue Sep 02, 2008 6:46 am    Post subject: Reply with quote
Hello,
Inverter problem!
try resoldering part on inverter board or replace capacitor that are visible damaged on power module.
