el_mejor
Posted: Thu Jun 12, 2008 7:46 am Post subject: Yamaha HTR-5630 - Servicemanual and schematics |
Hello there!
The mentioned receiver always shuts down to standby-mode after a few seconds after turning it on. Has someone any idea to solve this problem? I thought it´ll be only some bad solder joints.
Is it possible, that the amp stage is the defect, or is´nt this possible because of the protective-curcuit?
Is there some diagnostics programm? I read that on some receivers there is some kind of self diagnostics mode if you press some specified buttons while turning the receiver on. But it didn´t work on my receiver.
To start some serious measurement, I think I need the schematics. |
Posted: Thu Jun 12, 2008 10:23 pm Post subject: |
Thanks for reply, but I did buy a defective receiver to save money, not to spend it for a service manual to find out later, that I´m not able to repair it for less money.
Are there any other answers? |
Posted: Fri Jun 13, 2008 12:54 am Post subject: |
'Thanks for reply, but I did buy a defective receiver to save money'
What a fucking tightass! |
Posted: Fri Jun 13, 2008 1:12 am Post subject: |
There could be many things...
I used to work with various Yamaha receivers & to the best of my knowledge, they do have a "self diagnostic" feature which would help in finding the problem mainly directed to technicians with equipment by means of a code/number. To the average user it does not mean anything. Based on your description you could have a problem anywhere in power supply, preamp or final stage.
Yamaha's protection circuitry is pretty tight & monitors EVERYTHING from the speaker load down to every single supply rail & any current draw.
The most common is & has always been the output transistors which is not difficult to test with an ordinary vom but, on some of them rather a bastard to change & usually takes out a driver or a resistor or two. I can go on&on...
Unless you are familiar, you've got to have a print ---still not sure how much you'd be able to accomplish? |
Posted: Sat Jun 14, 2008 5:09 pm Post subject: |
| Anonymous wrote: |
Thank you for your very helpful post! I thought forums like this one exist, because people WANT to save money. If everybody has the money to afford new equipment, why should anybody repair his defective stuff?
@ vtech:
Thank you for your constructive guessings. I have already started to dismount the receiver and found out, with the help of my multimeter and the datasheet, that one of the two final stages is blown. I suppose, that the supply-voltages for the amplifiers have a defect too. I will check this and the prestage tomorrow. |
Posted: Sat Jun 14, 2008 6:47 pm Post subject: |
| Anonymous wrote: |
@ vtech:
Not necessarily, make sure to check the resistor(s) especially the low-ohm & emitter resistors & driver/predriver transistor/diodes that pertain to the particular stage. It is hard to say for sure but, sometimes you may loose just the finals & sometimes it may back up to predriver/drivers. Your supply is probably ok--now if you did not fingd any bad outputs, then I would dfefinately suspect something in the supply |
Posted: Sat Jun 14, 2008 9:45 pm Post subject: |
I checked all semiconductors and the emitter-resistor, I´m pretty sure that the final stage IC is the only part I have to change.
The only thing I am wondering about is, that the receiver even shuts down if the defective amp IC is soldered out. I don´t think that the control curcuit is detecting, that this part is missing. Because of this, I´m affraid that I didn´t find all the faults. Or is there any reset functionality to tell the receiver, everything is alright now?
ANyway! I ordered the spare part and hope I´d be successful. I´m reporting if the receiver is running or smoking after the repairment.  |
Posted: Sun Jun 15, 2008 1:59 am Post subject: |
Hmm...exactly what is the IC? I was not aware Yamaha has started using Ic's for outputs! I'm used to seeing discrete outputs & thought that you were able to find a defective output transistor which is rather easy to spot w/ a meter. If infact an Ic, how did you determine it being bad w/out any reference points or perhaps you have a diagram?
and you are correct: If it was a bad output IC, removing it , SHOULD allow the unit to at least stay powered On. ..at this point just not sure if you are in the right track & definately do not recommend any shotgun approach. |
Posted: Sun Jun 15, 2008 11:37 am Post subject: |
My problem is, that my english is not that good, to be sure, that I´m saying everything correct.
The defective part is an stk402-120, and I think this is an IC, an integrated curcuit. I thought this is meaning the same as discrete amp.
If you study the datasheet, you can see, that every channel of the ampflifier consists of to stages, one for every polarity. And one of the two stages is short-curcuited.
I tryied to switch the unit on, with all of the submodules connected to it. Because I assumed, that the receiver does shut down, because one of them is missing. Result was, that the reciver shuts down even quicker as whitout them. So I guess, that there could be another fault. But that doesn´t make so much sense, because I think the defective amplifier stage is the result of overload and not of another defect in the unit.
I ordered the STK402-120 already, so I will try to change this part and hope that the receiver is a smart one and just detected the missing part. |
www.lipetsk.name
boom.bg : аукцион -
MondeTech
SEO -
Онлайн поща -
