essexboy Guest
Posted: Mon Jun 23, 2008 6:43 pm Post subject: Strange readings on digital multimeter |
I have a Clarke autoranging digital multimeter. If I switch it to read d.c. or a.c. volts, without anything connected to it, it shows spurious constantly varying readings of up to several hundred millivolts. If I then connect the test leads and short them together, the readings fall to zero. It seems to read correctly when connected to a voltage source. Are these spurious open circuit readings normal, or is it about to die? |
Posted: Mon Jun 23, 2008 8:19 pm Post subject: |
Normal. |
Posted: Tue Jun 24, 2008 1:46 am Post subject: Re: Strange readings on digital multimeter |
essexboy wrote: | I have a Clarke autoranging digital multimeter. If I switch it to read d.c. or a.c. volts, without anything connected to it, it shows spurious constantly varying readings of up to several hundred millivolts. If I then connect the test leads and short them together, the readings fall to zero. It seems to read correctly when connected to a voltage source. Are these spurious open circuit readings normal, or is it about to die? |
Due to high input impedance & the nature of digital counter circuitry, it is a very common. _________________
PC800A & 1200A InterM • Схема POA-1500 DENON • HP COMPAQ PRESARIO CQ50 - WISTRON ASTROS • fdp8n50nzu fdpf8n50nzu Fairchild Semicon • Pye Q70 PYE (GB) • 2520 903 01B Keithley • AES-80 Assembler aes • PowerMac 7100 Apple • BX998A Philips • ME33 Boss •
