Phillips 28” Widescreen Problems/Repair
Roger
PostPosted: Mon Apr 25, 2005 12:34 pm    Post subject: Phillips 28” Widescreen Problems/Repair Reply with quote
I am having the following problem with my TV....how can I fix it and where would I get the spare parts to do so???
Model 28PW6005/05
Problems: -
a. Turning off after period of time when connected to coax port.
b. Turning off when selecting Scart channel.
c. Screen size changing every second.
Craig
PostPosted: Wed May 11, 2005 12:08 pm    Post subject: Reply with quote
The Painter IC is the cause of your problem....replacement is the only fix.
If you are going to attempt it yourself, make sure that you
1) Get the correct IC (there are 4 variants)
2) Be sure that you are capable of removing / replacing this surface mount IC without damaging the PCB
Bruels
PostPosted: Tue Oct 11, 2005 10:54 pm    Post subject: Philips 28PW6005/05 - Picture keeps flashing on/off Reply with quote
Hi
Ive been searching the web for weeks now trying to find a possible answer to my Philips 28PW6005/05 TV problem. I am not an engineer, but before I bring it to a shop, I would like to see if this is a known problem.
The TV is about 5-6yrs old, but lately it cant hold the picture. The screen blanks out for a few seconds and returns constantly. This happens after about 3-4hrs of running. Its almost like changing channel to the SAME channel.
When I turn it off and leave for a few hours, I get a view hours of viewing in before it starts all over again. I would appreciate any advice or direction.
Thanks
B
dante
PostPosted: Wed May 23, 2007 3:07 pm    Post subject: sound problem on my Philips 28pw6005 Reply with quote
mine has a different fault...
the sound keeps switching down by itself. after a time, if I keep my finger on vol + button on the remote, it stops and then starts again switching down. I didn't use it for a while (sick of this annoying fault) and when I plug it back it worked for few days and then started again with the same fault...
any ideas what could be wrong?
thanks!
PostPosted: Wed May 23, 2007 4:10 pm    Post subject: Reply with quote
as usual fault will be the painter ic, this ic is responsible for 99.9% of faults on this chassis
