Posted: Sat Jul 05, 2008 5:00 am Post subject: Replacing rca jacks on am/fm tuner |
Hi
How hard is it to replace rca output jacks in a Yamaha tuner? Getting a good signal on the tuner without constant jiggling the jacks' hook up is difficult. I have a 35 watt soldering iron, silver solder and some new gold plated jacks from RS. I am trying to work up the gumption to tackle the little job myself. The only experience I have soldering is with a few crossover components for speaker crossover networks and have no experience with circuit boards.
First, I might ask what wire or hookup is best to make the connections from the new jacks to the circuit board? I have junk electronic audio components around, maybe I can check to see if any wiring there is suitable. And I suppose the negative terminal of one jack can be jumped (connected) to the other negative terminal on the second and then run to the board from that point, is that correct? As you can probably tell, my electronic knowledge is very very rudimentary. So any instructions on getting these jacks swapped out without causing an explosion when I turn the thing on would be appreciated. Thank You RW |
Posted: Sat Jul 05, 2008 5:10 am Post subject: |
Radio shack if need be piece of cake. Screw out the old jack and there's only 2 wires.
Posted: Sat Jul 05, 2008 5:31 am Post subject: Re: Replacing rca jacks on am/fm tuner |
Anonymous wrote: | Hi
Correct... you can use the adjacent negative connection & use any wire as long as it is kept short.(If you plan to move the jack in a different place on the chasis requiring longer wire, then you should use a coax type. otherwise use what is already there) As far as solder though, you should rather use a rosin core solder which is used for electronics.
--& there will be no explosion regardless _________________
Posted: Sat Jul 05, 2008 3:52 pm Post subject: |
Thanks for the replies. If I run into any road blocks, I may return with more clever and insightful questions? |
Posted: Sat Jul 12, 2008 10:30 pm Post subject: Re: Replacing rca jacks on am/fm tuner |
Hi again, I want to double check on the hook up of the chassis mounted rca jacks. The old jacks (left and right) were formed in a single module. Removal of these creates an elongated opening in chassis. It looks like I will have to locate the new jacks nearby by making holes in chassis for the shafts of the jacks. No problem with that , is there? And so that I have the hook up straight, will the terminal tab on the new jacks, the negative, be in direct contact with the chassis (grounded to the chassis)? Then these same tab points are wired and soldered to the point on the circuit board where the old jacks negative side was, is that right?
Sorry for the elementary questions, I should have taken a basic electronics course somewhere down the line. |
Posted: Sun Jul 13, 2008 5:47 pm Post subject: |
Ground is ground on the hot side. |
333a and 334a HP • Uniwill • CT-2510S,2810S Sharp • 2sc4270 Sanyo • mrf247re Motorola • PHILIPS Q522.1E LA CHASSIS LCD TV SM Phi • 37LM611SZABEUWLJG SB-EX-SI 1386240394 LG • GDM17SE2T Sony • 2n6560 Semelab • pioneer sph-da100 sm Pioneer •
