ebe
Posted: Mon Jul 14, 2008 5:02 pm Post subject: Sony KV-X2991D - picture appears 5-10min after switched on |
Hello everyone!
I just got hold of a Sony Trinitron KV-X2991D TV. As I described in the subject, after switching it on, the sound starts immediately but the picture appears a few minutes later. When it appers, everything works OK until it's switched off. I'd like to fix it if possible and keep it for myself. Any ideas what it could be? Thanks in advance. |
Posted: Mon Jul 14, 2008 10:19 pm Post subject: |
Resolder the vertical IC. |
ebe
Posted: Tue Jul 15, 2008 1:03 pm Post subject: |
Thanks for the quick reply. I'll try that and I'll get back with the result. |
Posted: Tue Jul 15, 2008 6:12 pm Post subject: |
I checked and resoldered the entire pcb and nothing changed. Does anyone know where the chasys model is printed? |
Posted: Wed Jul 16, 2008 8:46 am Post subject: |
what is more likely with a set of that age is that the crt is on its last legs and it is taking 5-10 minutes for the crts emission to reach the point where the auto grey scale can balance the drives correctly, tweaking of the A1 control and/or short circuiting the heater feed resistor may result in a very temporary fix, only real cure would be crt replacement. the tv is fitted with AE2F chassis which came out in 1994. 14 years is a damn sight longer than you would get out of a modern set!!!!!! |
Posted: Sat Jul 19, 2008 9:18 am Post subject: |
Thanks a lot Gary. Tweaking the A1 did the job. |
