Posted: Thu Jul 17, 2008 10:23 am Post subject: ford focus no radio reception |
no reception on radio but cd player works fine does not pick up any radio stations the radio is factory fitted 6000 model 6 cd changer. |
Posted: Thu Jul 17, 2008 9:04 pm Post subject: |
Bad antenna or cable from radio to antenna. |
Posted: Mon Jul 21, 2008 8:21 am Post subject: |
A simple test would be to draw out the radio and hook up a temporary wire directly to its antenna connector. Also, check out the reception on both AM and FM bands. If only one of the bands doesn't work, then the trouble is in the radio.
Some Ford models use the heated rear window as radio antenna, on those models there is a filter/preamplifier unit fitted under the rear window. If that unit loses its power supply (for instance, due to a blown fuse) or gets faulty, you will have no radio reception. |
DCR-TRV410_X SONY • service.zip R8 FOSTEX • FDS6679AZ - P-Channel PowerTrench MOSFET • [pencap radial] TH Series Teapo • UREI-1181 . Various • MAIN B Rolsen • SCHNEIDER • FM AM Stereo-clipper 3312 Nordmende • info Samsung • 4010 SGS •
