minnie-me Guest
Posted: Tue Oct 14, 2008 1:56 pm Post subject: Benq DV2680 LCD TV backlight goes out in a minute |
I need help in fixing this set. After about a minute the backlight goes out. Sound is ok. Power indicator is still on. I checked the usual things, power supply, caps, bad connections, etc. There is no red color in the backlight as you may get with backlight going bad from age. Any ideas or service manuals are welcome. Thanks. |
Posted: Tue Oct 14, 2008 7:13 pm Post subject: |
Hold a flash light up to the screen and verify you still have a picture.
BenQ America Corp.
15375 Barranca
Suite A205
Irvine, CA 92618
U.S.A.
Tel: +1-949-255-9500. |
minnie-me Guest
Posted: Tue Oct 14, 2008 8:15 pm Post subject: backlight |
I tried that with a stronger light and all I see is black. I use that trick with monitors so I am familiar with it. I have a ground, 24 v, 3 volts and around 1 volt going to the inverter board. ground and 24 are the supply. The 1 volt may be the brightness signal. The 3 volt signal only goes to 3 volts when the lamps fire up. After about a minute, the lamps all go out and the 3 volt and 1 volt signal is still there. If I power off and then back on, the backlight comes back on. Off in a minute or so. Audio not affected. |
Posted: Tue Oct 14, 2008 11:06 pm Post subject: |
Check the one volt when you first turn it on. It should be around 12. |
minnie-me Guest
Posted: Wed Oct 15, 2008 2:18 am Post subject: |
It is 0.5 volts in standby and goes to about 1 volt when turned on. Where does this voltage come from? (which component) I don't have any schematics and its a multi layered board. |
FFH-376 trouble LG • Canon BJC-8200 Service Manual CANON • 04vari NOKIA • 019ABLK LG • 2sa1815 Sanyo • Philco PH42LED A2 LED TV SM PHILCO • 19 Marantz • L20V36 ZENITH • Aqarius CTD00 Hotpoint • 2raars NOKIA •
