PeterD1966 Guest
Posted: Wed Nov 12, 2008 1:34 pm Post subject: kx-f90 Panasonic Error Code 08 |
Please can somebody HELP
I have a Panasonic KX-F90
I hane the Operating Instruction Manual
I keep getting Error Code -08Recording Paper jammed. Re-install recording paper..
I useing CONNECT Fax Rolls KF10710 216mmx30Mx12mm But dont think that paper is the Problem..
I think the sensor is too finely set
The Roll will come out of the Machine OK. .But if you even look at it it will stop and give Errror 08.
Does any body know about this error?
I seen i an internet but its in other Languages!!
Can the sensor be by passed
Or does any know a work around for this
Please Help
Peter |
Posted: Sat Nov 29, 2008 8:32 pm Post subject: |
How come now a days..People are always trying to make a quick Buck??
If I had wanted a Manual - I would have asked for One !!
$11.77 First & Then Download WHAT ?...........??? Thanks for Nothing...Paul
Does anybody with this FAX Machine have the same problem??
Its being working 100% the last couple of days
But...This Problem can happen at any time..
Help Me ...Somebody......Pleaseeee.......... |
mpelevic Guest
Posted: Fri Jul 24, 2009 1:20 pm Post subject: |
Just use some cotton and alcohol to clean the sensor under recording paper.
It is located under the right side of scissors mechanism. |
PeterD1966 Guest
Posted: Wed Dec 18, 2013 1:58 pm Post subject: Oops... |
HI mpelevic ..
Its happened Again ..
I was Able to fix this Problem Before .. By Claening Something !!
BUT I can remember ..
From what i can see there are Two sensors . One is like a rocker switch - I think this is the Paper Empty one as it would detect when the Paper roll is empty - I by-pass it by putting some sticky tape over it !!
the other sensor is located within the guide plates - ( on the bottom of the Machine ) it look like a LED ?? . IS THIS THE ONE I SHOULD CLEAN ?
I know this is an old Post !!
But you never Know .. You might see this Some TIME ..
Regards
Peter D |
PeterD1966 Guest
Posted: Wed Dec 18, 2013 2:45 pm Post subject: Panasonic KX-F90 |
Fixed IT !!!
I will leave this Message Here as a remimder to MY Self !!!
OK .. Ya the Problem is with the sensor - in the Guide Rail on the Right Hand Side - ( Bottom of the Machine ) . Small Access and sensor is approx 10mm DOWN !!
It is quite a Small Opening to the Sensor - hence you need a very small... Q-Tip - I made one from Hair clip and dptical cleaning cloth !!
Everything is OK Again
This Secsor must be Extreamly Sensitive .. as the smallist bit of dirth will stop it working !!
Hope this Help ME .. or Some One else who has this Problem !! - |
VSX-916 Pioneer • std50nh02l ST • fdb2614 Fairchild Semiconductor • trouble EP2050 052 Minolta • PANASONIC TX-L26C10P Ch .GLP24.part4 p • XXl distortion Tech21 NYC • 2sc2582 Inchange Semiconductor • manualst Philips • 19780613 Graphical Bar Chart Examples xe • TARW99 Onkyo •
